I turned on my oven to preheat last night and for the first time i could smell a strong gas odor. i gave it a few minutes thinking it would go away, but it got worse, so i turned it off and decided not to use it. it looked as if it was working properly the oven burners all looked like they were working. and all my range burners work.
SOURCE: older frigedaire range oven quit working
the problem is in the ignitor it is not pulling enough amps to open the safety gas valve even though it glows doesnt mean it is good
SOURCE: Smelling Gas and Soot in Oven
well its pretty normal u will smell gas when its preheating but if u think its not then u can pull the oven out and check the gas line connection is tight if it is then u can also get a spray bottle of soapy water and spray the whole line and if u see alot of bubbles then there is ur leak and for the soot problem u can use the clean cycle which all it does is reach a very high temp and pretty much burns everything like crumbs to a crisp and all u have to do is basically wipe it out with a damp cloth and maybe a mild soap and sponge good luck
SOURCE: I have a propane gas range when I turn the burners
HI is the tank low on gas it could be that causing the smell
SOURCE: oven will not light-broiler works
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Replace the oven ignitor its the electronic pilot next to the oven burner its not longer getting hot enough to ignite the gas, the stove can blow up if not change .
