Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
All drivers up to date. No yellow question/exclamation mark or a red X in device manager. But Xstill exiists in task bar on speaker. So in control panel/souns there is nothing to change. it`s empty. Other suggestions?
right click on the X what options are there you might need to configure the speakers read my earlier post carefully
looks that
i cant read that what happens if you select one of these blury
I updated high definitions audio contrloler, uninstalled but it always says that drivers up to date and everything works fine, but there are no sound device and X in task bar.
right click on the SPEAKER icon in the toolbar what options are there
All optinions as they have to be: 1.troubleshoot... 2.playback devices 3.recording devices 4. sounds 5.volume control options...
right that
is there a green tick on the speaker in either the recording or playback tab ((please read my earlier post very carefully))
playback and recording devices are empty. "sounds" are full, but inactive. volume control panel is empty.Sorry for my language. English is the second one. I read your first post,but everywhere nothing to select. no speakers,no audio devices are shown
what do you mean playback and recording devices are empty do you have a sound card installed ?
as I said there is high def sound device installed. I have sound card installed with the newest drivers, but the problem exists. sound card worked on XP but very unstable. this PC was bought Vista included, so I think that problem is about bad driver or too old sound card for win7
SOURCE: no audio output device installed
first i would see if all my audio drivers are up to date.
use this program:
http://www.drivermax.com/
thanks
CBZ
SOURCE: sound problem in hp pavilion dv2000 with window xp
well u need to tell me which series of pavilion dv2000 Note it's located on the label as in this example: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
SOURCE: cant able to install audio driver
hi,
plz downlaod the latest version and try to installl it...
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_show_1373.html
if the problem continues
change it to xp service pack3
and still problem continues it is due to the audio port connection
device not being recognized plz repair it using your warranty.....
thank you for using fixya,rate my answer
vijay
SOURCE: hp pavilion cd/dvd drive disappeared, not showing
What you want to do is, first, make sure that the cables are connected to the cd/dvd player. Then, when you are in the device manager, right click on your computer name all the way on the top above all the devices, and click on scan for hardware changes.. If nothing comes up, restart computer and try this step again.
SOURCE: No audio output device is installed on hp pavillion dv6000
First go online go to HP site and go driver download and puch in the the Product no of your PC it will bring up the entire list of drivers for your PC. Now you need to do a BIOS update than restart the PC. it should work fine and the pop up should not come anymore.
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps don
have you ever had any sound on your computer ?
first you tell me there is an x then you say there are no x what the
