Cars & Trucks Logo
Anonymous Posted on Jan 16, 2013
INGINE DOESn't START P1683 - 2003 Dodge Caravan
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
3697
Points
8
Depends on what are you hearing when you try to start. Does the Engine sound like it is trying to start, does the starter even spin? or when you turn the key you hear 1 click but all the lights and everything comes on? If you hear multiple clicks and your lights are dim, that means your battery is done. There are a few things you can check before spending a lot of money. First check to see if your battery is good, 2 check the battery terminals to make sure they are tight, 3 check the condition of the battery cables if they are old or rusty, try to replace them with new ones, they cost 8-10 bucks. 4 try to replace the starter relay in the engine fuse box, this costs 12 dollars usually. if none of these are the issue, then its either you starter solenoid or the starter motor has gone bad. I suggest instead of replacing the solenoid, replace the whole motor which comes with the solenoid.
Code p1683 on my dodge status what do I need to replace
P1683 metering oil pump temperature sensor circuit malfunction
Code p1683
DTC P1683 - Driver 5 Line 3
The "P" implies Powertrain, but I understand this code to relate to your vehicle's computer which is unable to boot up properly as a result of being unable to read certain data. This may be from a faulty PCM, or low voltage to the unit. I would check both, and ensure you check the ignition as several things validate voltage from there.
Code P1683 & P2176
P1683 is : Powertrain control module fault
P2176 is: Minimum Throttle Position Not Learned
My wife has ran out of gas several times in our 1999 chevy blazer, nowwhen I try to start it the ingine trys to turn over but it wont start like its not getting gas can you hgive me some suggestions
Possibly burned out the fuel pump. Lay next to the truck with your head by the gas tank. Have your wife turn the key on but not crank the engine. You should hear a light whirring sound of the pump priming and it will last a few seconds and stop. If you don't hear the pump priming, thump the tank near the sending unit as she turn the key. If it runs, you'll need to replace the pump. If it still doesn't run, check the fuse. If the fuse is good and you have a volt meter you can trace the wires to the pump and check for voltage (12) as the key is turned on. If it has voltage, replace the pump.
There is a massive leak coming from beneath my ingine. I never have had a problem in the past. The water rapidly drips but nearly pours out, leaving a fishy odor. I looked beneath where the water is c
could be a water pump,or a hose clamp is loose on bottom radiator hose.You will have to follow leak to find problem.You can take to Midas and tell them to check exhaust and they will raise up and see your leak and show you where it's coming from.
2005 infiniti g35 two questions number one my check engine light doesn't come on whatsoever , not even when I start up the car however the other lights work ????? Number 2 my car idles at 1200 rpm...
sounds like there may be a few problems - bad vaccum line somewhere for the idling problem - the check ingine light should only come on when oil is low or needs changing or there is another problem
2answers
New starter installed spins but wont engage ingine
The starter sprocket wheel is thrusted into engaging the flywheel by a big solenoid. That solenoid is integral part of the starter motor. If the starter turn itself but it doesn't turns the engine then either it was incorrectly installed or the thrust solenoid is defective.
Simple test: take out the starter, attach it to a bench, connect to it thew power cables from a battery (the minus one to the body, the plus one to the big connector bolt) then short the big connector bolt to the small one with a screwdriver - the solenoid should activate, the sprocket should be thrusted forward and the motor should start spinning it.
If that doesn't happen then the starter you just bought is defective, replace it. If that happens the starter was incorrectly installed on the engine. Reinstall it correctly.
Water leaking from on top of front ingine box
your radiator hose is broken and thats where the leak is coming from pls. change the rad. hose/ fill in colant and start the car.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
