How can i download win8 drivers for lenovo 3000 Y410
Sharing a good link with you, i got a good key here, after i used it, my works became easy and quick, worthy to owe one. www.fastbackorders.com
If you have upgraded the Laptop from Windows Vista to Win 8 , Did you do a Hardware compatibility test? You may be in for bit of a mess. Take a look at this: http://howto.cnet.com/8301-11310_39-57390888-285/check-your-hardware-for-windows-8-compatibility/ The driver's are another issue, sometimes you can use Win 7 drivers, change compatibility, and modify the drivers to work with your hardware. I have done it , and it can be quite a pain, and quite frankly not worth it. I would suppest Win 7. When you "jump" two OS's ,Vista to Win 8, it doubles your fun.
SOURCE: lenovo 3000 y410 webcam
it's nothing much...Fn+Esc solved the problem...the drivers were already installed.
SOURCE: Lenovo 3000 Y410 Touchpad Freezes
Hi, you must update the sound driver of your equipment series 3000, which came with fault, exists a boletin that it informs about it, or send you to the telephonic Number of attention to the client of your locality where they can give you more details.
SOURCE: my Cd dvd drive not working for Lenovo 3000 Y410 Laptop
ur lens is getting weak
pls try this take out the dvd from drive u will see a shiny eye like thing it is lens try to clean it in circular motions with very soft cloth used to clean lcd's and then try those dvd 's otherwise u have to get the drive replaced ur lens is weaken due to some faulty media and excessive use it is a normal wear and tear process
pls rate me fixya for my help
SOURCE: Wifi driver of Lenovo Y410
Here is the link for Intel....you will need to know the model #
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17227
and here is the link for vista drivers at Lenovo
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=6
I hope this helped...if so please rate me ...thanks ..The Fang
SOURCE: drivers Lenovo 3000 N200 mod?le 0769-A43
Enter Here for all your drivers for lenovo 3000 n200! Rate me for this! Thanks!
PLS REPLY OR COMMENT. THANKS
