Philips 37FD9954 37 in. HD-Ready Plasma Television Logo
mark folsom Posted on Jul 11, 2007
Tv will not turn on--- flashing red led
When i try to turn on my tv, the green light will come on for about 10 seconds, (no picture or sound) then will flash red until i turn off the set. When i try again the same thing happens. i took the back off of the tv and it was a little dusty but not too bad, i blew off the dust but that didnt help.
  • mark folsom Jul 13, 2007
    i saw on another site that it could mean the power box or power chi may have gone out and needs replaced, i dunno
  • Anonymous Mar 27, 2014
    TV WILL NOT COME ON NO SOUND NO PICTURE UNPLUG PLUG BACK IN COMES ON WORKS FINE LIGHT FLASHES
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 13, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4228
Points
11
You will need to take the TV in for repair. The red light is the TV's way of telling you the protection circuitry has been tripped. There is most likely a problem with the power supply inside the TV.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 11, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1326
Points
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
NO PICTURE OR SOUND ,GREEN LED STAYS ON FOR 10 SECONDS THEN A RED FLASH . PROCESS REPEATS ITSELF
Hi
You have to check how may time that led flashes. check the link for more details about led blinking in sony bravia tv.
www.electro-medical.blogspot.com
Toshiba 36HFX72 power button flashing
Not sure right off bat, however unplug it from the wall for three or four minutes plug it back in it might reset it?
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
1helpful
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
1helpful
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
