I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Depending on the model of the tv, you could scroll ch dn past ch 2 and you should cycle through your inputs. if that doesn't work try holding down the two vol buttons on the tv. that could access the menu for the tv
You are trying to connect the TV by AV setup. You have to select the input selection to TV to AV. If the TV have a Menu button on its front panel, you can enter into its menu options, surf through, and select the input selection window. Here you can select input to AV. If there is no 'Menu' button on the front panel of the TV, you can'd do this selction. You must have its remote control to select this option.
Hello If the TV has a "Menu" button at its front panel, you can select its menu, and can select the input selection. If not, you can't do with wthout a remote control. Just buy an RCA universal remote control. If there is no Menu Button at the front panel of the tV, there is no other way to get AV selection to your TV. OK.
Try to see if any of these four methods will work. Sanyo TVs 1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote 2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV 3. Press TV/AV or INPUT SELECT on remote 4. Press SETUP, choose TV/AV, switch to AV
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this: Press the "MENU" button on the TV. Press "CH Down" until "Channel" is highlighted, and "MENU" to select it. Press "CH Down" to highlight "List and Labels", and "MENU" to select it. Press "CH Down" to go below channel 1, you should see "FRNT" displayed. Press "MENU" to get out of the Menu system. You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources?
Depending on the model TV you have, there are up to four ways to change the video source:
Through the on-screen menu controlled by your remote
Through the on-screen menu accessed through the Menu button on your TV's front panel
Through the TV/Video, TV/Component, or Source button on your remote
Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote
To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
Turn on your TV.
Press the Menu button on your remote. The Main Menu appears.
Select Input, and then press the Enter button. The Input menu appears.
Select Source List, and then press the Enter button.
Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV
To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
Turn on your TV.
Press the Menu button on the front of your TV. The Main Menu appears.
Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote
To use your remote to change the video source, follow these steps:
Turn on your TV.
Press the TV/Video or Source button. The current source appears on the TV screen.
Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV
To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
Turn on your TV.
Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
I tried the above solution to no avail. My TV model is GE 25gt520.
The menu options don't allow the AV input to be selected.
Thanks for trying.
