My Blackberry also wouldn't turn on, till a sharp tap at the top left of the screen made the screen flicker into life and I realised it was on, just no screen. After intermittent screen failing, repeated tapping seems to have fixed the problem. I'll upgrade to a new Blackberry when my contract allows.
Richard
SOURCE: blackberry pearl won't turn on
The sim card may not be put in correctly, or it may need to be slid back or fourth a little bit. I had this same problem, but continued playing with my phone until I figured it out, now of course with a blackberry it took awhile to come back on, but no more irritating red light and black screen. Voila!
SOURCE: hoe to unlock Blackberry pearl 8100
Hi pratik. please follow the recommended steps.
Option # 1: GSM Phone Source
These guys provide you with remote unlocking of the BlackBerry Pearl 8100 and also the BlackBerry Pearl 8700g.
How it works is pretty simple. You pay for the unlocking service,
and when you submit your order, you must include the IMEI number for
the Blackberry you are unlocking in the notes section when you are
making the Paypal payment. The IMEI Number can be obtained when you
enter *#06# from your phone’s keypad, it will display
a 15 digit number ( If you have trouble obtaining the IMEI this way you
can also find the IMEI number in the Status menu ). Once your order is
processed and unlock code is ready, you will be emailed with an unlock
code and instructions on how to enter it.
Models supported, including but not limited to are the 8100, Pearl, 8700g, 5xxx Series, 6xxx Series, 7xxx Series.
You have to pay $35 for their service and the turnaround time is usually less than 24 hours. You can visit GSM Phone source here
Option # 2: Unlock to Talk
Unlock to Talk is another good option to unlock your BlackBerry
Pearl. They have over 150 satisfied customers with completed orders for
unlocking their phones. You can also check the list of their customers
with their BlackBerry IMEI numbers and their corresponding Unlock Codes here.
For Unlock to talk service, you end up paying $35.95. Their turnaround time is also around 1 business day or upto 48 hours.
You can visit Unlock to Talk here
Option # 3: T-Mobile or Cingular, your carrier
Yes, you can ask your carrier for an unlock code for your Blackberry
and guess what, they do it for it Absolutely FREE. So, what is the
catch? The only condition which atleast T-Mobile imposes on its
customers before it gives out the unlock codes for the Blackberry Pearl
or any other cell phone is that you have to be under the contract for
atleast 90 days or 3 months before they can give you the unlock code.
So, if you have the patience, I would recommend that you wait for this
3 month time frame before calling up 611 from your T-Mobile phone, talk
to customer service and get your unlock codes.
In my search for the Blackberry Unlock codes, I found out that a lot
of people mess up before they have no idea how to enter the unlock
codes correctly. So, follow this method to enter your Blackberry Unlock
code
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as
instructed. No need to hit keys twice to get a letter either. Type m e
p p d to display the first five levels of SIM locking. Most companies
use network locking so the Network should display Active. All other
states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked.... i've also attached a link for the visual demo f the above given process
http://in.youtube.com/watch?v=IrM-WMy6WIM..
thank u for using fixya..
SOURCE: blackberry pearl 8100 wireless internet support
The 8100 does not have wifi, but the 8130 does.
SOURCE: manual gprs settings fro blackberry pearl / 8100
im using airtel gsm sim ,so i want to activate gprs so give the manual settings of blackberry pearl of 8100 series
SOURCE: free unlock of blackberry pearl 8100
To unlock your phone you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number.
I can recommend this one (cheap and reliable).
Click here to unlock your Blackberry Pearl 8100
Note: don't share your IMEI number on free forums like this.
