Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Kitchen range random chatter noise
Jenn-air kitchen range produces a random chattering noise. Range functions all work (oven heats, burners heat, timer works, etc). Noise occurs whether we are or are not using the range. Model number SCE3430W. The model slected below was as clse as I could get to the actual model.
  • rmajeres Feb 12, 2009
    Thanks. The chattering noise sounds more like a relay closing and opening rapidly rather than motor noise?
    New Friend:
Our Jenn-Air SCE4320 of 1997 made the random chattering, behind the digital clock. There is a printed circuit behind the chrome bezel (two screws under), no point in removing the bezel. The board used to cost $200 but is no longer available. By accident, we turned the dial to read "5". The clock thinks this is an instruction, and waits for the next entry. We never enter. The chattering has stopped while the clock waits. We haven't had a squeekie, for nigh onto a weekie.
Posted on Jul 20, 2013
  • 25 Answers
Could be clock motor or fan motor keeps running.
Posted on Feb 12, 2009
SOURCE:
Oven does not heat up Broiler works but takes a while to ignite. Range top burners work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 29, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Oven slow to start heating (sometimes) not always. But once the gas burners ignite then the oven heats up quickly
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 11, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Oven takes too long to heat up on Jenn Air gas oven
you need to look at the oven igniter to see what color it is. if it is orange it needs to be replaced. it should glow white hot in order to ignite. hope this helps.
Oct 13, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven not heating up
I would contact JENN AIR about their range . Many problems with things we have never seen . SORRY
Jan 01, 2018 | Jenn-Air Pro-Style® JDS9860BD Dual Fuel ...
Jgr8855bds range - oven problem
that's too long, check to see if you have flame in the broiler section, i'm thinking not. see if your ignitor is just staying on without igniting burner, ignitors will produce that much heat in that amount of time. if no flame at butner, replace ignitor.
Mar 31, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Mar 09, 2008 | Kitchen Ranges
Whirlpool Drop-In rear burners shut off
The gas line was stuck clean nozzle w/ small neddle and clean burner set the edge of the burner in order complete gas will be burn.
Jan 04, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Igniter works sometimes.....stove won't heat
Check your oven thermo. sensor at room temp. you should have between 1 to 1.1K ohms. If not replace it. You also should check your burner and oven relays.
Sep 19, 2007 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
170 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
