Ipod was connected to sync music and poped a message up as I was trying to disconnect saying syncing. After it was safe to disconnect music was erased from the ipod. Now when it is connected to a computer itunes freezes. Reseting didnt work either, redownloaded itunes, and tried on a different computer and it still freezes itunes.
Need to reformat your ipod - don't disconnect the ipod until you hit eject - ever you should be able to use it again try a different cord and reformat then have fun cause you get to reload all the music unless you were able to save your iTunes library
Well it worked well enough to be able to get it to read it in itunes but itunes cant sync it up now
Do you have a wall plug? If not try this turn off your computer or laptop whichever has your itunes on it - plug the laptop into the wall if it isn't already and then plug in your ipod - let it completely charge the ipod (do it overnight so you don't mess with it) - once charged power up the laptop or computer and see if the ipod tell you it is okay to disconnect - disconnect and check the ipod - then check it on the computer or laptop if that doesn't work you're gonna have to wipe it - SORRY just thought about this method it worked once on a 3rd generation 8gb.
All it does is say that it needs to scan and fix but when I go into to try that it doesnt seem to do anything. The ipod keeps comin up it is connected. Ive tried reformatting, restored to factory settings as well.
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
