1993 Suzuki GSX 750 F (Katana) Logo
Anonymous Posted on Jan 16, 2013
Wireing diagram for the cluch wires 1993 katana 750 from the handle bar?
For got where to plug in the harness from the cluch on the bars to the main or block??????????
Mike Haynes
Level 2:
Novelist:
  • Expert 157 Answers
  • Posted on Jan 18, 2013
Mike Haynes
Expert
Level 2:
Novelist:
Answers
157
Questions
Helped
54100
Points
329
The clutch switch circuit is a yellow wire with a green stripe. The handlebar switch has 2 male bullet type connectors that will pulg into female connectors of the same color. One will be on the harness from the r/h handle switch and I believe the other is on the main harness, r/h side of bike under fuel tank. It dosent matter which goes to which just mate male to female.
  • Anonymous Jan 22, 2013
    Thank you, it worked.
5 Related Answers
tombones
  • 3567 Answers
  • Posted on Apr 05, 2009
SOURCE: ''I am looking for 1983 suzuki GSX 750 S Katana Owners manual''
Google " service manuals suzuki "
or go to www.repairmanuals.com
or try your local library. Often guys will donate manuals to the library.
You might find a free pdf service manual on this site, they have a ton of them.
http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this solution. Thanks!
Anonymous
  • 1392 Answers
  • Posted on Jun 02, 2009
SOURCE: 2008 GSX-R 600 Ignition Switch Removal and Replace
You will need to remove the gas tank, air box, and possibly some hoses to get to the plug. Not a hard task, just time consuming on a newer bike.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: stator wiring overhaeting
My 96 GSXR was doing this too. I found I had oil leaking into the stator case. This had "washed" the insulation off the windings (I think) causing it to short out. It shorts worst when it is hot. Now when I disconnect the generator while running it runs great. Reconnect, and a huge blue spark arcs across the plug. This causes a huge current flow at this plug (back and forth). I haven't gotten all my parts yet to try out my diag. Check under your stator cover, or just continuity test it in the bike (OHMs meter).
sean1969mitc
  • 13 Answers
  • Posted on Jun 05, 2009
SOURCE: where can i get a free wiring diagram for my 96
i have come across some public libraries that keep manuals its a long shot or try a local bike dealer they may photo copy one for you
Anonymous
  • 5 Answers
  • Posted on Sep 21, 2009
SOURCE: Suzuki 1999 Quadrunner LTF250F wiring harness issue
no power to my magneto on my 99 suzuki LT-F250F dont know what one of the four other wires should be power i found the ground please help
Ignition wiring diagram
Go to http://www.alpha-sports.com/suzuki_parts.htm, search the year of your bike, find your bike and then open the wiring diagram that will be available
3answers
1993 suzuki katana 750 wiring diagram
I looked and couldn't find anything on it but I think your best bet would be to join a suzuki katana 750 chat forum those guys that go on those sites know almost everything there is to know their stuff or know where and how you can find out
I recently had my wiring harness replaced on my 93 katana 750. he also cleaned carbs, fuel filter, drilled jets bigger (he did this because it had after market exhaust slip ons and i didn't want to pay for...
When too much fuel is being supplied to the carburetors the engine is flooded. When you remove the spark plugs it allows the fuel to dissipate enough to allow the engine to run again. Drilling out the jets is not an accurate/preferred method for changing the jet size. Most of the time the jets end up being drilled too big. You can save money by just buying main jets. A jet kit usually will come with the slide needles made with a different taper from the stock needles. You may need to break down and buy a jet kit or a least replace the main jets with accurately sized main jets (not drilled out jets). In other words your main jets are just too big.
You turn the handle bars to the left the head lights turn off
Sounds like you have a short. The headlight and the tail light are on the same fuse as well as a few other lights. I'd look closely right where the main harness goes from the frame to the front end. There is a lot of flexing and movement in the wiring harness in that area. Look for wires that could have been rubbed by the fairing.
Good Luck
steve
1helpful
1995 yzf 750 wiring diagram, starts wont rev
Hi and welcome to FixYa,
Would the wiring of a 95 YZF750 R/SP European model help?
Good luck and thank you for asking FixYa.
Was riding 95 gsxr and my head lights went out
Had the same problem. There is a green plug in the wire harness situated under the tank on the left hand side of the frame. This plug tends to pick up corrotion. Try to unplug the two parts, if you have difficulty to unplug it this might just be your problem. Replacing the plug is the only solution. This plug connects the wiring from the light switch, to the lights. If you have difficulty tracing this plug, trace the wires back from the light switch on the handle bars.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
