How can i unlock this phone so i can also use it in brazil?
Hi, You can unlock a Motorola CE0168 safer and easier using unlock code. You can get the accurate unlock code for a Motorola CE0168 from www.Mobile-Unlocker.Com at affordable cost with free unlocking instructions. good luck mate.
SOURCE: I need a user manual for my Motorola CE0168
Please follow this link for your manual. It gives you two options, but both are sufficient (Rogers/Fido).
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00002&show=globalSupport&productID=bf9d5a7be49c9010VgnVCM1000008206b00aRCRD
Let me know if this does not work out for you and we will find another solution.
SOURCE: unlock motorola ce0168
call to your network customer care they ll provide you the code to unlock
SOURCE: my motorola CE0168 was locked...
Ideally it is best to get the unlocking code from the service provider who had given you the phone in the first place.
Only if this is not possible you can try the following links:
SOURCE: motorola ce0168 unlocking codes
If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
