Mine is not refurbished and still works wonderfully but can not watch it because we can not buy the base stand, neck, and bracket w/screws it came with because Sharp has discontinued making the pieces. I have looked on Ebay, Amazon and other distributors that sell parts but they have all been out and do not expect to receive any more due to the fact that it has been a discontinued item. Please help so I can enjoy my TV again!!
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
SOURCE: I can not remove the stand from my sony aquos tv.
With the 4 long screws removed, it should come out.
Here's where you can download the manual for the LC-46D62U.
http://www.sharpusa.com/files/tel_man_LC46_52D62U.pdf
It has the instructions you need for the stand.
SOURCE: 32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Testimonial: "Thank you for the information. I had a feeling that I would have to replace the set."
SOURCE: need to buy the stand base for sharp aquos 32-gp1u
Try looking and contact this place:
www.shopjimmy.com
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Hi. I need the 4 screws to mount the TV stand to
They are metric screws, you van get them at Lowe or HD, try M5 or M6. they are about 35cent each so you can try difference length.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
