2006 Mercedes-Benz ML 350 Logo
Eric Oppong Posted on Jan 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mercedes ml350 won't sart..when i turn the ignition it makes a sound but the engine won't start
When i turn the ignition i can hear the engine try to come on but it won't start
David
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 14, 2013
David
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2677
Points
I have a 2006 ml350 sometimes it starts and other times it will not....?
Kelly La Rue
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 93 Answers
  • Posted on Jan 15, 2013
Kelly La Rue
Expert
Level 2:
New Friend:
Greenhorn:
Answers
93
Questions
Helped
19039
Points
291
I don't know if this is helpful but an engine needs three things to work. Air, fuel, spark.
5 Related Answers
Anonymous
  • 710 Answers
  • Posted on May 02, 2009
SOURCE: engine oil light came on, on my mercedes ML 350, 2006 model.
IT MEANS THAT YOUR OIL LEVEL IS VERY LOW AND NEEDS TO BE FILLED. CHECK THE OIL LEVEL WITH THE DIPSTICK IF EQUIPPED. IF NOT, THEN ADD 1 OR 2 QUARTS OF OIL TO SEE IF THE OIL LIGHT GOES OFF. IT MAY TAKE SYNTHETIC OIL SO DON'T PUT CONVENTIONAL OIL IN IT IF YOU SEE A MOBIL 1 SYNTHETIC OIL RECOMMENDATION STICKER UNDER THE HOOD. IF YOU ARE UNSURE THEN BRING IT TO A QUALIFIED TECHNICIAN A.S.A.P.. HOPE THIS HELPS. GOOD LUCK.
Anonymous
  • 297 Answers
  • Posted on Aug 11, 2009
SOURCE: MERCEDES C240 WILL NOT START, ENGINE TURNS OVER,
Yup, either NO fuel or NO spark !!
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Nov 02, 2010
SOURCE: ml350 replaced a/b cam position sensor reset
P0010....'A' Camshaft Position Actuator Circuit (Bank 1)
P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013....'B' Camshaft Position - Actuator Circuit (Bank 1)
P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1)
P0020....'A' Camshaft Position Actuator Circuit (Bank 2)
P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2)
P0023....'B' Camshaft Position - Actuator Circuit (Bank 2)
P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2)
I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
Anonymous
  • 62 Answers
  • Posted on Jun 30, 2011
SOURCE: i have 2006 mercedes ml350
you have a {tps} throttle position sensor problem
Anonymous
  • Posted on Jul 11, 2011
SOURCE: Mercedes ml350 2003 starting problems Vehicle
It happen the same to in my truck it was the starter and alternator
1helpful
2015 ML350 4matic will not start
Check for the battery power if is enough to give a crank start,check for the battery terminals if they are clean to get a good contact,also check for the ignition switch itself,or check whether the power wire connected on to the starter either is corroded or disconnected.
1helpful
2004 Mercedes c240 won't start, turned the
It is located on the transmission where the sghift cable connects to the transmission.
Won't start after running out of gas
However, your problem is most likely in your fuel injection system. When you turn your ignition to 'ON' you should hear your fuel pump come on. If you do, you may only need to turn your ignition OFF/ON a few times for the fuel system to pump gas back to your engine. If you do not hear it come on, your fuel pump may need to be replaced. It'll need to be checked by someone with enough information to make an accurate diagnosis.
2006 dodge stratus won't crank and cruise control won't light
Must not have been much of a mechanic. If the engine runs and sounds fine sometimes and other times it doesn't then it does not sound like a mechanical problem with the engine. Sounds more like a issue with either the ignition system or fuel system.
1helpful
2answers
2005 Altima won't start, hear clicking sound coming from fuse box,key stuck in ingintion,won;t turn over,tried to jump start.
the clicking that you hear is coming from the starter relay. sounds like your ignition starter switch or ignition lock cylinder is bad.
CAR WON'T START-NO PRESSURE FUEL
When you turn your key forward (pre-ignition) can you hear your fuel pump engage and have you checked your inline filters?
Won't start
Switch on head lights or cabin light. If they doesn't come on or is weak, the battery is flat. Ensure that you switch off the lights.
With ignition switched on, assuming the lights on the instrument panel cames on and your immobiliser is deactivated, turn ignition to start. You should hear the solenoid at the starter making a click sound. If not, the battery is flat or the starter solenoid is faulty. If it does make a click sound, the battery could be too low to turn the starter or the starter is faulty. Assuming the immobiliser is working correctly, and the starter tries to turn the engine but it doesn't want to turn, the gasket could be blown and the cylinder filled with water, or the engine could be seized.
Hope it is not the last case. MarioCpt
My 96 yukon wil not start. Sounds like it will crank over but won't. It is not the fuel. I changed the ignition coil still won't start.
try spraying some carb cleaner into a vaccum hose and see if it will run. If so then you have ignition but no fuel delivery. If not then you have an ignition problem. make sure you hear the fuel pump hum when you turn the key to the run position. It should run for +/- 5 seconds then shut off. remove gas cap and listen for fuel pump operation through the fill hole. If you can hear the pump then you have a fuel injection issue. If the engine starts and runs for a few seconds then shuts off then you can suspect the crank or cam position sensor. The fuel pump runs through the oil pressure switch which could also be an issue.
Are you able to start the truck with application of the gas pedal?
1helpful
I have a 96 pontiac grand am that doesnt start all the time
Starting Problem # 1: Engine Won't Crank At All
Scenario: You turn the key, but nothing happens: And by nothing, we mean there is no dash light, no sound, nada. The first thing you should do in this case is to pop the hood and check the battery. Either the battery is completely dead or there's a wiring problem in the starting system. Try jump-starting the battery. If that doesn't work, you'll probably have to call for assistance.
Scenario: When you turn the key, you hear a rapid clicking sound, and the dash lights dim. This is your classic low-battery symptom. Jump-starting the battery should get the engine to start.However, if you keep experiencing this problem, you could have a bad battery or alternator, or it could be some­thing as simple as a loose alternator belt. Take your car to a mechanic just as soon as you can.
Scenario: When you turn the key, the lights on the dash come on, but you don't hear anything. Make sure you have the shift selector all the way in park. Move it out of park and then back, or try starting it with the shifter in neutral. If your car has a manual transmission, make sure you have the clutch pressed all the way to the floor. If that doesn't help, you can try jump-starting the battery, but it probably won't work. There's a good chance your car has a bad starter or a problem in the starting circuit. That could mean a prob­lem in the ignition switch, neutral safety switch or starter sole­noid.
Scenario: The dash lights come on when you turn the key, and then go right out, and the engine doesn't crank when you turn the key to start, But, the lights slowly come back on when you release the key. This is another classic: the bad battery connection. When you turn the key to start, the starter pulls so much current that it breaks the connection. Then, when you release the key, the connection slowly comes back. The connection provides enough power to turn the dash lights on, but not enough to crank the starter. Cleaning and tightening the battery terminals may fix this prob­lem.
Scenario: When you turn the key, you hear a single, hard clunk. Turn the headlights on and try again. Do the lights dim slightly when you turn the key? If so, you probably have a bad starter or a seized engine. If the headlights don't dim at all, or just barely dim, there may be a connection problem between the starter solenoid and the starter itself.
Scenario: When you turn the key, you hear a loud, scraping or grinding sound like metal on metal. The starter drive is bad, or the ring gear on the flywheel damaged, or both. You may get the starter to engage if you try turning the key a couple of times, but let go of the key right away if you hear the noise again. If the car does start, you should drive it right over to local repair shop and have the problem fixed.
Starting Problem #2: Engine Cranks but It Won't Start
Scenario: The engine seems to crank normally, but the engine doesn't even sound as if it's trying to start. Is there gas in the tank? Gas gauges are notoriously inaccurate. If you have to move your head to one side to get the needle to move off empty, try adding some gas to the tank.
Scenario: When you first turn the key on, you don't hear the fuel pump run. In cars with electronic fuel injection, you should hear a light hum a few seconds from around the fuel tank. That's the electric fuel pump running. If you don't hear the fuel pump run for a couple seconds when you first turn the key on, try cranking the engine until the oil light goes out. That may start the pump running and allow the engine to start.
Scenario: The engine cranks normally, and it sounds like it wants to start, but it won't. You may have flooded the engine. Hold the gas floor and try again. (Let the gas pedal up when it finally starts). If it's raining out, the ignition system may be wet.
Scenario: The engine cranks unevenly in a repetitive-sounding pattern. You may have a bad timing chain or timing belt. Call a tow truck and have it towed to the repair shop.
Starting Problem # 3: Engine Starts but It Shuts Off
Scenario: The engine starts right up, but shuts off as soon as you release the key. This is the classic symptom of a bad ignition switch. A new switch should fix it.
Scenario: The engine starts and runs, but when you put the transmission in gear, the car lurches and the engine shuts off. The converter clutch in the transmission torque converter probably is engaging when it shouldn't. On some cars, you can bypass this by disconnecting the torque converter clutch solenoid; but unless you know which wire to pull, forget about it. Call for assistance.
Scenario: The engine starts and runs, but seems to idle slowly and stalls when you come to a stop. This probably is a fast idle problem. When the engine is cold, it's supposed to idle a little faster than normal to keep the engine running. You may be able to drive using two feet until the engine warms up: one on the gas to hold the idle up a little and the other for the brake. However, don't keep driving it this way. Take your car to your repair shop just as soon as you
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
