Question about Motorola Mobility H700 Wireless Headset
My motorola H700 keeps staying red when charging
My Motorola won't charge. It stays red when plugged in. Any suggestions? Is it broken?
I had the same problem with my H700. I left it on the charger overnight and it was still red the next day. Before I tossed it, I decided to try discharging the battery completely by leaving the mic boom in the open position overnight even though the blue light wasn't coming on. After doing this I put it back on the charger and it charged properly. It's been working fine ever since.
Posted on Oct 13, 2007
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Posted on Jul 31, 2007
I have the same problem.
My H700 when I charged, only turn on a red light, the when is charged turn off the light. My Doubt is that the other ones i have turn on a red light then a yellow one and then a green one when is fully charged, the new onw i have only lights up the red one.
I want to now if this his normal.
Thanks
Posted on Nov 06, 2007
SOURCE:
My Motorola H730 won't stay charged
Jess
Are you charging with boom closed and closing boom when not in use?
Mark
Motorola Support
May 29, 2012 | Motorola Mobility H730 Bluetooth Headset
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
May 19, 2010 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
What tells when fully charged?
On the Motorola H700, the light will turn from red to green.
link to your online manual
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Good Luck
Jul 14, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 charge issues
The rechargeable battery may have reached it's limit of recharges. You can try leaving it on until you no longer see life (any light) coming from the H700. You want to drain it completely. Than charge it, (take note of how long it takes to reach full). If it dies like before in 15 minutes than the H700 is dead. You can take it to a Motorola store & might be able to exchange it for less than you first bought it. Or you can go here (Click the link) for a new one. http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=Motorola+H700&image12.x=13&image12.y=15
Luck!
Mike
Apr 01, 2008 | Motorola Mobility H700 Wireless Headset
H700 no change
sounds as if you all have defective units
Dec 05, 2007 | Motorola Mobility H700 Wireless Headset
Pairing h700
try pressing firmly against the hinge area, press the call button until the purple light comes on, then open the boom with still pressing firmly on the hinge. Keep holding firmly and the purple light should stay on while you pair
Nov 16, 2007 | Motorola Mobility H700 Wireless Headset
Trouble connecting h700 to phone
First: When charging the light should be steady. If the battery is less than 20% charged it should be red. More than 20% it will be yellow. Fully charged it should be green. Make sure your microphone is closed when charging.
Second: Have you "Paired" the H700 and the phone? If not you need to. To put the H700 into "Pairing Mode" do this:
Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Your phone and H700 should now be connected.
Hope this helps a bunch!!!
Jan 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
1,880 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
