Hotpoint WMA40 Front Load Washer Logo
Posted on Jan 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
The door to my washing machine will not catch when shut and will not lock if held shut and a washing cycle started. The door springs open and currently the only way to use the machine is to gaffer tape the door in position.
I have replaced the door interlock switch but I am still having the same issue. Could this be a fuse or a more sinister electrical fault?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
481
Points
My Hotpoint WMA35 door light indicator will not light up when a wash is turned on.Is the door contact switch easily changable? -i am thinking this may be the problem. james.
Dominic Parsons
Level 2:
New Friend:
  • Expert 118 Answers
  • Posted on Sep 14, 2009
Dominic  Parsons
Expert
Level 2:
New Friend:
Answers
118
Questions
7
Helped
47411
Points
291
I would get a new door or catch from the hotpoint website hope this helps
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
4helpful
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
2helpful
2answers
UNABLE TO OPEN DOOR AFTER WASH
5helpful
How do i open the door on hotpoint WD440, latch is broken?
Please rate my solution.
Thanks.
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
1helpful
2answers
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Hotpoint WMA62 front door will not lock
If the door locked light is flashing then you probably have a control module problem.
You could try a new door lock but I don't think this will solve the problem..
Make sure the door is shut properly, and that the door catch is o/k.
Plz rate this solution.
Thanks.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
