1990 Nissan 300ZX Logo
Posted on Jan 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transmission fuse blown
Where is transmission fuse located
Kelly La Rue
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 93 Answers
  • Posted on Jan 15, 2013
Kelly La Rue
Expert
Level 2:
New Friend:
Greenhorn:
Answers
93
Questions
Helped
19066
Points
291
It will be located with the rest of the fuses. Fuse blocks can be in more than one location so check manual for all locations. Manual should tell you which fuse is for the transmission.
Why doesn't it shift to 3rd gear?
Sounds like a speed sensor has failed. Could also be that the transmission fuse has blown. Check fuses and get codes cleared. Other things, that will affect the transmission shift points, would be the manifold absolute pressure MAP sensor, throttle position sensor, PRNDL switch (shifter location switch). Probably just a power issue.
1helpful
2answers
How come my back running ligts are not working? brake lights,turning signal all work??
There is a switch on the transmission that is activated when reverse is chosen although on automatic transmission cars it is usually connected to the gear selector in console or colomn. This switch may need replacement. First check fuses .
2answers
Fuse location for backup lights
In the fuse box and usually labelled. If not, pull each fuse one at a time and check for blown fuse.
4helpful
3answers
What causes the reverse light not to light when im reversing my car
Hi .
Reverse light works on a switch that's is located on your transmission . so the problem is with the switch or fuse or maybe even globes are blown ? good luck.
My 2006 Nissan Altima is stuck on park
Hi I had the same problem with mine when I called a dealer they said I had to change the transmission which cost me $1200. I asked some mechanics and was told they need to take the transmission out if you are told the same thing don't believe them turns out it just a bad fuse that blown. Look in ur fuse box for a blown fuse (fuse box located in the car by the driver side bar just below it on the left and the other fuse box in front pop the hood.) Locate the blown fuse and replace it I have made a video on YouTube to help
3helpful
2answers
My nissan frontier blows the automatic transmission fuse when attempting to start and it will not go into overdrive
Replace the transmission range switch for starters, if that doesn't correct the problem you have have a shorted shift solenoid on the valve body inside the transmission.
10helpful
3answers
My 03 Kia Spectra will not go into gear. I want
the fluid is drained by removing the transmission pan located under the car. make sure you buy a transmission filter kit so you can change the filter and gasket. the trans fluid is added to the dipstick tube, where you have located the dipstick.
Subaru sti faults codes my sti cranks but wont start key symbol on dash flashs
The key symbol on the dash normally will go out when the ignition is turned on, if it doesn't, you have a security system issue as I'm sure you've already guessed. I would start by checking the fuse box under the hood on the drivers' side of the engine compartment for blown fuses, this could be as simple as just a blown security system fuse. The under side of the fuse box lid should have all of the fuse labeling locations, you can also look in your owners manual for fuse locations and definitions. If you don't find any blown fuses you will have to go to someone who has a scan tool that can pull security system codes, the generic scan tools can only pull engine/transmission codes. I hope this info helps...(subytech1)...
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
