SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Your machine should now work. hope this helps.
there are 2 screws round the back, take these out, lift the front of the lid slightly and bang the top to the rear to relaese it from the tabs.
the buttons are all plastic clipped in and can be removed and cleaned with care not to snap anything.
Hotpoint’s are designed to go into test mode when the start button and
you see ‘D:end’ (or similar message)."
just keep getting error message F-01.. anyone know what this means?
