I have GE cordless 5.8 ghz and have registered the first phone on the main base. The other phones display a message on the screen of please register. When I go through all the registration steps that I went through on the first phone, it doesn't work.
I tried your solution - putting the phone on the answering machine charger and it worked! Thank you!
I just purchase that same model and I had the same issue as you where the phone on the main station worked and the other 2 sitting on their own base station didn't work. What I did to fix the problem was to put each handsets (one at the time ;-) ) on the main base (the one with the answering machine). The Charge/In use light flashed a couple of time then the handset showed as Ready. I then put each handset on their individual base station and they all work fine now.
good luck
Martine
With a little searching I was not able to confirm this phone could handle more than one cordless handset. Are you replacing a defective handset or trying to add a second. If adding, do you know if it can handle the second unit (is it advertised on the box, in the user guide, etc?) If replacing, you most likely have to de-register the old handset on the base unit before you can register a new one. If you are adding, try de-registering the working handset anyway and registering the new one. If the new one registers and you cannot re-register the once working phone you will know either the system cannot handle two phones or (if the new one will not register but you can again re-register the original) that the new handset has a problem and should be returned.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
SOURCE: Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Same issues with new out of box setup. Per the manual, the GE 5.8 GHz main station is supposed to support up to 4 handsets. Manual also stated that phone shoudl "register" with main station after being set in the main station for 20 sec.
I have an uniden 3 phone corldless with answering machine. phone s1 says to register on main base. Have tried many times. What am I doing wrong
don't know how to register phone
i'm having the same issues
I'm having the exact same problem. I don't know know what else to do.
