Lift your car put it in jack stands for safe Put your rear seats down your able to seeing the top strut Mount nuts if you are planning to not install new spring don't trying to remove the struts center nut Unless you're using spring compressor tools
you will need several specialized bike tools that will make this cost prohibitive for the DIYer unless you plan on doing more wheels. Most local bike shops can sell you a replacement wheel for between $35 and $50 and remove and reinstall the freewheel, rimstrip, tire and tube and reinflate it for about $8-10. Also the quality of this replacement wheel will be a much higher than the original Huffy wheel.
If you still want to do it yourself, you will need a freewheel removal tool for your specific brand of freewheel or cassette (there are about a dozen different types of tools out there, so make sure you get the right one). You will need a spoke wrench of the right size for the spoke nipples you are using, there are three common sizes and a couple more odd size ones out there. You are looking at about $20-$30 for those tools. You should use a truing stand to true the wheel after the spokes are replaced ($150-$400) but you can "get by" with using the brakes in your bike as a reference. Spokes will run you $1-$2 each. If you don't have a special metric spoke ruler ($10-$15), most LBS's will measure them for free (all bike parts are measured in metric). The details of lacing a wheel and getting the tension right is beyond the scope of this short answer and I recommend that you either try to find a book on the art of wheel building at your local library or buy one off of Amazon ($25-$45), there are several good ones out there and video tutorials also. If you plan on doing more than one wheel then I highly recommend it and take the time to learn the art, there are few of us left out there that can actually build a wheel these days.
