SOURCE: Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
SOURCE: kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
SOURCE: Kenmore Elite error message F 02
Here is what the manufacture says about F02 - Below this are my comments
If
the drain time exceeds eight minutes, the water valves are
turned
off and “F/02” is flashed.
Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed,
then
four minutes later the “F/02” error code will be
displayed.
Possible
Causes / Procedure
1. Check the drain hose and make sure it is not
plugged
or kinked.
2. Unplug washer or disconnect power.
3.
Check the electrical connections at the pump and make
sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5.
Plug in
washer or reconnect power.
6. If the above does not correct the
problem, go to step 7.
7. Unplug washer or disconnect power.
8.
Replace the pump.
Phil's comments---->
If you washed a rug with a rubber backing or
small articles like baby socks you may have a plugged up pump. To access
the pump lay on the floor and remove the 3 screws holding the lower
panel of washer on. Pull down and out on the panel to remove. Lay out a
lot of towels under the unit, I mean a lot... Look in the center for a
white cap about the diameter of a large cup, it will have a handle on it
to turn, turn this left(counter clockwise) to unscrew. This will
unscrew and pull out, but be careful when it comes out so does all the
water. Clean out the trap that is in your hand and anything you see or
feel in the sump area the trap came from. Reassemble and test. If this
does not work you will more than likely need a new drain pump, that is
the component on the right of that trap you just cleaned out.
Testimonial: "You are a Guru! Thank you so much for informing us about the "hidden" trap which housed an ankle sock, .90 & lint! works like a charm now!!"
SOURCE: PF error code on kenmore
PF stands for Power Failure. Caused by unplugging and plugging in within 30 seconds, or a short power surge or outage.
