Magic Chef CER3740 Electric Kitchen Range Logo
Pat OAk Posted on Jan 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magic chef electric fee standing range model 35ja-26x
The oven stays warm even when shut off
How do I fix it?
  • Pat OAk Jan 24, 2009
    Thank you I will check that out.
Anonymous
Level 3:
President:
  • Master 1,214 Answers
  • Posted on Jan 24, 2009
Anonymous
Master
Level 3:
President:
Answers
1214
Questions
0
Helped
565816
Points
3697
Sounds like a shorted element. This can happen if the element shorts to ground near the middle of the element. Current will then flow from the unswitched side of 240 VAC to nuetral or ground, heating up the same as if on 240 VAC.
I set my magic chef oven at 400 degrees,and it shuts off before it reaches the temp.
Have you checked the internal temp with an oven thermometer?
The thermostat might need calibrating or replacing, or, (if electric) the oven might be seeing an "overload" condition and shutting off.
My Magic Chef model 9112XUB wall oven will not light. It has power and gas but will not ignite.What can I do to fix it myself?
If this model has electronic ignition, you can open up the broiler door , turn on the oven, and look to the rear of the broiler...there should be a sort of glow plug getting reddish/orange. If not, the oven won't light and you will need to obtain an ignitor for the oven. these are available through appliance parts distributors such as Bell Parts Suppy. If it is a standing pilot model, then first check to see if the pilot is lit...if it's not lit try lighting...if it won't stay lit, then the thermocouple is probably bad and will need to be replaced
1helpful
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
2answers
Magic Chef kitchen range needs oven door hinges replaced
slide unit out they should be on both sides of the unit
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Surface Heat and other lights will not light up. Will not get hot but is trying - gets slightly warm. This includes burners and oven. The cooking light will come on in the oven but nothing more. The...
you have a power promblem start where the cord connects to the range and go back from there to the fuses before you pull it out turn off the breakers loose connections will cause the cord to short out sometimes
5answers
Oven won't light
Hey im sorry to hear that...
I fix many ovens., however not really familiar to yours...
However instead of searching for thermostat, try looking for either thermo-couple, falme flaiure device or falme safety device these are the three main termonologies used....
Hope this helps......
Im sorry cant provide you with a full on solution ... but my guess is that your is probably a thermocouple......
2answers
Magic Chef electric range model # 3888VRA
Sounds like the oven control needs to be replaced.
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
