Black & Decker 18V Cordless Drill/Driver Logo
robert pickering Posted on Jan 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you use 18v lithium battery in old 18v drill
Repair Ahjoshe
Level 3:
  • Black & Decker Master 885 Answers
  • Posted on Jan 15, 2013
Repair Ahjoshe
Level 3:
Answers
885
Questions
0
Helped
642916
Points
2112
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Testimonial: "worked great thanks"
1helpful
My 3 year old battery P104 will run my drill about 10 secs and then quit. I restart the drill and the same thing, another 10 secs and stop. I checked the voltage on the battery and it is fully charged. ...
Your batteries are tired and don't put out enough amps to power your drill. They may show 18V in them on a tester and show fully charged on the charger but one or more of the cells inside are just worn out. If you got three years out of them you did extremely well. The only fix is to replace the batteries.
1helpful
2answers
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
2helpful
Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger I can't get these to work! The charger does what it should but when I have a steady green light the batteries do not power my drill, when I...
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
3helpful
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
We are only managing to drill 4 x 6mm holes in paveing slabs, drill is 18v and only 1month old.
Ryobi is one of the cheapest drills. They are good for small projects. You need to upgrade to a better drill like milwalkie or Dewalt. Seems if you are drilling in concrete you need a corded hammerdrill. This will get the job done.
Can you charge a 18v lithium battery in a nicd charger?
Do not try this since the charging circuit for lithium batteries are different than nicad! Improper charging of lithum batteries can cause a fire.
3helpful
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
I need charging instructions for my 18v lithium batteries.
the lithium batteries are not like nicad you can cahrge them whenever you want and will not get a memory. Just put them on the charger and when the ready light is on they are done.
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
