Question about Electronics - Others
Low voltage output from inverter
I have an 800 watt inverter with 1200 watt peak output. Runs off 330 ah battery bank. New unit and noticed when I turn on LCD tv, light turns off for few seconds until tv powers up. Checked voltage meter and it shows only 186 volts. tested outlets with multi tester and found 186 volts there too. tested outlet directly on inverter and tester showed 232 volts. Tested at end of 2 foot cable that runs to selector swith for generator/inverter.and found 192 volts. Replaced cable in case of damage and still same test results. Pluged an extention cord into inverter directly and found 192-4 volts at outlet. I have had a 500 watt and 1600 watt inverter in same system(500 watt until 2 days ago)and both gave out 230 volts with no problems. Why is there 232 volts directly at inverter socket but significant loss of voltage as soon as something is plugged in to it (without any load on it)
  • 4 Answers
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
    New Friend:
    Problem Solver:
  • 14 Answers
High performance low voltage inverters with high stability and preferencial price:
http://www.veichi.org/electric-drive/low-voltage-inverter.html
Posted on Mar 17, 2016
    New Friend:
  • 9 Answers
The problem is in inverter display or in inverter, please call electrician and checked it. Otherwise change your inverter and buy new one of 900 VA.
Posted on Jun 03, 2015
    Problem Solver:
  • 12 Answers
Ignore peak, that means nothing. RMS * 1.414 = peak. RMS is the actual usage you will get, thats all. Peak doesnt mean it will supply the peak wattage for a short period of time: salesmen with no electrionics training tell people this and its a big fat lie.
See what the unit is drawing, use a clamp-on ammeter on ONE lead (not both, or it will read 0). That shoudl tell you if your device is drawing too much. You should only be able to run that device UNDER the 800 Watts (watts = volts * amps, not including loss of efficiency which might be 10% or more, and even greater when warm)
Source: I'm a maintenance electrician. Like the home-builder kind, same apprenticeship (more hours; 10,400) but also with much industrial training in PLCs, transformers, converters, inverters, motors, controls, etc.
Posted on Mar 31, 2009
    New Friend:
Check grounding on case of inverter if it is not do so test again and what country dose a TV run on 250 a socket?
Posted on May 19, 2013
SOURCE:
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
How many 12v batteries are needed to run a 15000w inverter properly
It is normal to use only half of the capacity of a battery and this is called 50% depth of discharge (DOD) so the watts of a battery is volt X amp hours eg a 12 volt bat @ 200 AH would be 2400 watts but you can only use half of that other wise the battery will be stuffed, so all you have is 1200 watts, if you have a 400 AH battery you would have 2400 watts, you also have to know the capacity of the battery and this is call the C rating of the battery once you have that you can work out how many hours it will run for.
On an of grid system I would not use any less than 6oo to 700 AH @ C100
It is normal to size the batters to energy demand in KWHrs per day of (AC load )
Hope this help.
Feb 07, 2016 | Inverter Electronics - Others
Motherboard, the inverter output voltage
Inverter output can vary, but anything greater than 150 volts with a high impedance meter (with a capacity of 2000 volts) can be considered good. The meter loads the circuit by itself and normally the RMS voltage that most meters register is lower than the peak to peak voltage of the circuit. If a scope is used, use a 10:1 reduction probe, and your voltages can be anywhere from 300 volts to 1200 volts with 650 to 750 being the normally accepted good range. Where your brightness control is set will have direct impact on the voltage you see.
Nov 01, 2012 | Acer Aspire 5920-6727 Notebook
Can you daisy link two inverters together positive to positive neg to neg ac out to increase the watts
This will cause big problems. It will not work and will likely cause both inverters to fail. Power inverters must create the 60Hz sign wave from a crystal controlled internal frequency driver. It's like a clock that keeps the timing at 60Hz. 2 independent units will have slightly different clocks both in time and frequency. This would cause the output waveform of one unit to be out of phase with the second. If they are out of phase, they will look like loads to each other and likely fail. It would be possible if the inverters had a way to link their clocks or use only one clock. This could be designed in however I have never seen this feature. You can hook up multiple inverters to the low voltage side (12VDC), just don't hookup their 120VAC output side. Hope this helps.
Jun 07, 2011 | Inverter 1000-2000w Peak Surge Power
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
I have a motormaster eliminator powe box 1200
Look on this site and see if yoou can find one with:
Correct dimensions
Correct voltage
Correct terminal connections
Don't worry if capacity is a few more amp hours. Some batteries have improved the capacity.
Use your measuring tape for size.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=393246&k=battery%20sealed
Oct 23, 2009 | Black & Decker Electronics - Others
Power drop
Hey, Question: Is the 2400 watt the peak rating or the continuous rating of the unit, and what is your power source for the inverter. If 2400 is the peak, the 1200 is probably the continuous. Your 75 watt fridge will draw probably 150-170 watts to start up, which will load the inverter to draw 15-17 amps of load on your 12 volt power source. If the battery supply is weak, the current draw at startup will cause the voltage to drop and set off the alarm. Getting the start up out of order may work for a while, but will eventually blow the internal fuses on the inverter, or possibly blow out the capacitors. Check the condition of the battery supply, and make sure the bar fridge is in good working order to resolve this problem.
Jul 18, 2009 | RoadPro RPPI-2500W Inverter
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Electronics - Others Logo
    2,622 people viewed this question
    Top Electronics - Others Experts
    Marvin
    Marvin
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
