I put my set of JBL Creature II back to work after quite a long time of being unused. I noticed that the left speaker (the one without controls) produces noticeably less treble than the right one. I.e. the produced sound does not include as many high frequencies as the sound produced by the right speaker. Does anyone have some hints of what this could be and how it can be fixed? I have tried using a different cable to connect the speakers to the PC as well as different music tracks to verify the problem.
SOURCE: JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
SOURCE: My left JBL Creature II speaker has a green light
I had the same issue and applied ezimme solution from Jan 04, 2009 and it worked perfectly. Thanks ezimme!
SOURCE: JBL Creature 2.1 Left Speaker not working
Hiya
Too late to resolve the original poster's worries, I can assume, but I arrived here when searching on account of the same problem and resolved it. This is going to sound implausibly condescending, I'm afraid (and excuse th elack of technical terminology!)...
I couldn't get my left speaker to work exactly as above, but then looked carefully at the shape of the respective cables leading to the sub. You have to fit the triangle shape of the lead into the triangular shape of the hole. The speaker CAN be connected what *feels* like correctly, but is in fact connected incorrectly (ie, not all the way in).
This is more a problem with the left speaker than the right since it's a triangle and the right is a square, and can be a little fiddly.
Anyone else experiencing the same problem should probably take a quick moment just to check this isn't it! :)
