Question about Polycom SoundStation Premier EX Audio Conference
I have the soundstation2 and cannot get it to conference call. When I dial the 1st # and press the conf. button it put them on hold only for about 3 seconds and I cant get a dial tone to call out, so when I start dialing it goes back to the person on hold and they can hear me dialing.
SOURCE:
SOURCE: polycom soundstation Ex - no dial tone
Ditto!  must be a common problem.  Anyone have any internal schematic manuals of the guts?  With an internal schematic, I could probably figure it out.
Posted on Jan 06, 2008
marsrover
  • 682 Answers
SOURCE: conference problem
repeat you setup for all station you want to connect to it.
Posted on Sep 18, 2008
SOURCE: VTX1000 Conference phone
thats very simple,simple when you press CNF dial the number when the call recieved press join & the number 3 for a two sec .you will be connected
Posted on Oct 10, 2008
  • 23 Answers
SOURCE: We have a Avaya soundstation2 2490. We had to buy
have you verified the proper COR has been assigned to the station?
call you dial intra office extensions?
what is happening when you dial?
Posted on Aug 15, 2009
JackHeath
  • 1049 Answers
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
Posted on Oct 01, 2009
Hi there! How do you do a conference call on this phone? thanks! Christina
the link / conf. button, after receive or placement of a call tell person to hold. press conf. or link button. "put's them on hold" dial another prty or phone inside tghen press key again.
Nov 23, 2009 | Panasonic KX-T7633 Corded Phone
How do I connect 3 phone calls on a Polycom Soundstation 2. There doesnt seem to be a hold button
It depends on what system it is installed on.
NUT, generally, with the first caller on, press flash you will get intercom tone again, dial 9 and connect to the next party. Once connected, press flash again and you should be connected to the original party.
Oct 23, 2009 | Polycom SoundStation2 Audio Conference
How to make conference call in KX-T7730
Generally on most systems you have a conf call button or feature code. If so, You place the first call. press the conf call button. this puts that call on hold you either automatically get a second dial tone in your ear or you need to press a line key or dial 9. once the 2nd call is placed press the conf key again and the calls will be joined.
This is a general description some systems have variations of this, Hope it helps.
Dan
Jul 30, 2009 | Panasonic KX-T7730 Corded Phone
Is there a Conference Call feature on ATT MLS 12D?
If by conference you mean inside and outside parties connected together the answer is yes. You should have a CONF button on the set. You press CONF, dial your second call and press CONF again. You can press CONF again and do it all over again to add a 4th party. There are restrictions and the conference is not amplified.
Here's a User guide to Partner phones. pdf page 3 has CONFERENCE instructions.
http://public.carl.airpost.net/Avaya/Partner%20Phone%20User%20Guide.pdf
Carl
Feb 27, 2009 | AT&T Lucent MLS-12D Phone
Feature 71
If you have a manual, look up RECALL or FLASH or LINK. Specifically Feature 70 and FEAT 71. In your spare button set, you probaly have gray buttons labeled CONF/TRANS and LINK. Now you use them depends on how you are transferring calls. Are you on Centrex or do you have 3 way Conference calling from the telco? That's the one where you can establish a 3 way call and hang up and the other two parties stay connected. If you have that, you'll use the LINK button to get second dial tone, dial your number, and press LINK again to establish a 3-way. LINK time is defaulted at 600 mS, and is adjusted in A 4. Misc programming under LINK. You may just have 3-way calling, and that means the middle party has to stay on the call.
If you don't have 3-way conferencing, you can use the system to conference (using two lines), and the CONF/TRANS button. There may be some disconnect supervision (ie DS cabinet) issues, Supervised/Unsupervised programmnig changes, and transmission losses in conferencing, so your mileage may vary. Best would be maybe to conference with a VoIP trunk or other lossless facility. Anyway, you put the first call on hold, make the second call, then press CONF and the held line to establish a 3-way. At this point, if you have Disconnect Supervision, you can press conference again and leave the call, or put the call on HOLD to keep it on your phone and the other 2 parties can still talk to each other.
Carl
Jan 27, 2009 | NorStar M7324 Telephone
Conference Calls/Transfer
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
May 21, 2008 | NorStar Meridian M7310 Phone
Conference calling
While tlaking to 1st party press 'CONF' button,
Dial 3rd Party's No. (0' first for outside line)
Press 'CONF' Button
Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
Feb 07, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
CONFERENCE CALLING
CONFERENCE With call in progress, ask party to hold.
Press Transfer, receive interrupted dial tone.
Dial desired number
After call is answered, press Conf. Conf LED lights.
Three-way conference is established.
If one party hangs up, other two remain connected. Conf light goes out.
Dec 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Conference call
While speaking to one person, press the "conf" button... Wait for a beep beep, hit 9 then dial the other number... talk to the new person... press "conf" again... talk to everyone
Nov 08, 2007 | Panasonic KX-T7633 Corded Phone
Polycom SoundStation Premier EX Audio Conference Logo
96 people viewed this question
Top Polycom Lands Phones Experts
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
