SOURCE: The brand new HD GoPro
If this is a new camera then I would put in in the box and return it. This sounds like it could be the small fusses (not user replaceable) on the board or a problem with the cpu or power section of the camera. The fuses pop on quite a few cameras and will show about the same life. If it is under warranty then I'd not mess with it too much and get a replacement or a refund. If this is a real common issue then it indicates a design flaw so you might exchange cameras and end up having the same problem again.
If this were a older camera I'd suspect the battery's needing replacement. Since it is new then it has to be something a bit more serious.
hey everybody , I found one solution for those dead GOPRO hero 3 cameras go here http://fixinghero3.wordpress.com/ I recorded the video and create a blog to help people , because i was desesperate too with my go pro but now after that i update it and works fine more info in the link !! thanks
