Setting one touch numbers:
press function 72
set
press 1 for one touch numbers
press a position on the soft pad example 01
enter fax number with round buttons
set
enter name with soft pad letters
set
continue with more numbers or press stop to end.
For GROUP DIALING
Setting Group Dial:
press function 73
set
choose group dial
set
press program 1
set
name the program such as field offices.
set
press the one touch numbers you entered in the first step for this group,,,,01,02,05,08,17 etc
press set
press stop
load document in feeder, press Program 1 key, START
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
its for the Panasonic UF890
