At first if I pressed the buttons on the time panel the ovens would work, but now the ovens will not come on at all, there is no ignition clicking it seems to be stuck on auto
Phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
I have a range master cooker, where both ovens do not work, because the clock/timer is not working, but if I switch the griddle/grill on for approx 1 hour everything works fine!! The clock starts flashing, i press reset & switch the ovens on! Once the griddle has cooled down, you have to start the entire process again the following day! This appears to be a vary common fault.
No help but I have exactly the same problem
any answers?
Make sure your clock is set to the correct time or the gas won't come through .
