Same problem here - I looked in the manual, and did not see this particular problem Noticed if I lifted the head slightly, it worked, so put rubber bands around base to raise it just a bit. Worked one night. Now red light is flashing.
You can't post conmments that contain an email address.
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and
not turning green
Humidifier is working than stops:
? Ensure that water level sensor is
assembled properly.
? Clean water float
? Call service center and request
replacement water float
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
I have an elephant humidifier with a broken fan. I just posted the problem, but I doubt there is a solution. I'm sure the tanks are interchangeable from looking at the manual, if you don't mind an elephant (I don't know if the lid is interchangeable). I would hate to throw it out and have one more thing in the landfill. Maybe I could send it to you?
the kitty will turn off if you rotate the dail all the way to off (straight up). Look at the pink arrow on the dial. You will feel that the knob does not want to go any further when you are at "on" which is the lowest setting and no steam comes out. But you have to go all the way to off.
The elephant and frog models have actual on/off switches but this one its just the dail.
Same problem. Red light turns on after 20min of operation with 2/3 water.
Same problem here.
