Motorola Mobility RAZR V3x Cellular Phone Logo
Posted on Jan 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Usb port not function
My charger ok but my my cable usb not function
Anonymous
Level 2:
Sniper:
  • Expert 92 Answers
  • Posted on Jan 24, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
92
Questions
0
Helped
62212
Points
234
Sometimes you need the appropriate drivers for you computer to make it recognize the phone. If it is not a driver issue you may need to try a different usb cable.
Driver Link for motorola
32 Bit Windows
64 Bit Windows
You will have to register on the site to download the drivers.
Where is place on charger to plug USB cable?
AnUSB cable can be plugged into a n USB charger. The charger has a USB port that the cable plugs into, it is usually compliant with most USB charging cables. If your charger has a fixed cable, i.e. for a single make, you cannot fit a USB charging cable.
Most computers now also have the charging facility even when the computer is switched off.
Jul 03, 2015 • Cell Phones
2answers
My zeepad isn't tuning on what do I need to do.I charge it for a of hours and still not coming on.
make sure the battery is ok and fully charged. try to switch on with the charger charging. Is the charger ok ?. if it switches on with the charger hooked up the battery is at fault.
2answers
I need a usb charger What can I do?
The problem of your getting usb charger can be solved by this site. This is not a usb charger but also a charger of multi ports. It has 6 ports each port is providing 2.4 A what is so demandfull for any kind of usb charger. Go and check it out.
http://www.amazon.co.uk/dp/B00MGJAXC8/
2answers
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
2answers
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit.
Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing.
Try using a different charger that will deliver 5 Volts at 2 Amps...no less.
If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
I CAN NOT CHARGER MY DEVICE IN USB
USB connection cables comprising of ports on computer telecommucnations devices are versatile outlets to managing multimedia. First the USB port on the device makes device to device connection where resoruces can be shared among several function requests. Second, the USB port on device least allows to derive power charge from another device only has to be attained from power outlet. For example, while a device is plugged into another device for media resources sharing is least like to attain power charging simultaneously. First use the USB port to power charge from an outlet to attain required functioning status. Circumspectively, the devices that have USB ports has several functions either as media resource sharing also for power circuit charging only each separarete process is attained where it is impossible to power charge a device while using the same port to derive functionality.
1helpful
I lost my charger for my Sanyo x1250 digital camera. Cant i use my USB cable as an alternative charger?
Did the mains charger connect to the camera's USB port? If so, it will probably charge from any USB port including your computer. Otherwise, no.
I found a charger (and batteries) for this camera on Amazon by searching for "Sanyo x1250 charger".
Nov 30, 2010 • Cameras
8helpful
2answers
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 • Cell Phones
2answers
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
2answers
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
