Philips Dvd Player Vhs Video Tape Player Recorder Vcr Combo Convert Dvds 2 Tapes Logo
amia Posted on Nov 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems with Philips vhs recorder/dvd player
I have a digital adapter box and I have another vcr that is hooked into the digital adapter box. Do I need to disconnect that and hook the Philips dual player into it? Do I need a coaxial cable? I have the audio and video cable already. I just want to connect the player so I can watch my vhs tapes and dvd movies. Please help
Grubhead
Level 3:
  • Philips Master 5,755 Answers
  • Posted on Nov 24, 2017
 Grubhead
Philips Master
Level 3:
Answers
5755
Questions
Helped
1662301
Points
11417
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
2 Related Answers
Anonymous
  • Posted on Apr 13, 2008
SOURCE: hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Anonymous
  • Posted on Nov 21, 2008
SOURCE: Philips 4GB GoGear Flash Audio Video Player - Video Error
just download youtube converter it is freeware.add the file ,choose the format i.e avi ,get the output file .now load it on philips media converter it will read and work.
2answers
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Need to record dvd to vhs
you can hook another vhs vcr to your dvd / cd player and make sure they are both on Line 1.....
Also, your cables..... output jacks from player to input jacks on recording vcr
Hope this helps jlp
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
2answers
Dubbing vcr to dvd-
its the copy protection system doing this. if you have another dvd player or vcr, you can hook that up to a time base corrector box and run the output out of that to the dvd recorder, allows recording from any source.
Dvd to vcr?
Plug the DVD connections into the INPUT on the back of the VCR. This is sending the signal from the DVD player INTO the VCR.
If you are familiar with the VHS to VHS, then remove the VCR and replace it with the DVD player.
I hope this helps :)
If the question changes it will send me an automatic message. So if this was not enough info, just let me know! I'll actually hook mine up to record this way then I'll be able to tell you step by step if need be.
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
