Sony Cyber-shot DSC-W50 Digital Camera Logo
ELAINE BEVAN Posted on Jan 13, 2013
My digital camera seems to have lost my holiday photos. The memory card is inserted but I get a message saying no file.
I had tried to import onto the computer earlier but this was unsuccessful so I opened the camera while it was still plugged into the computer. Could this have erased my file ?
faysal_haroo
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 20 Answers
  • Posted on Jun 12, 2015
faysal_haroo
Contributor
Level 1:
New Friend:
Night Owl:
Answers
20
Questions
0
Helped
1442
Points
46
Active your foto again with the help of recevory software do this.
5 Related Answers
Anonymous
  • Posted on Mar 19, 2008
SOURCE: File Error report on a W80 camera....
If you bought your memory card on eBay, there is a good chance that is the problem, as i had that issue myself....after dealing with the seller and getting my money back, i went and bought a sony 4GB card from Circuit City, worked fine for a while, and then got the same error. I have a feeling it has something to do with the camera's software. I havent tried the battery trick yet but its next on the list
MGHuck
  • Posted on May 09, 2008
SOURCE: No CF card
The camera body has a tiny switch marked "CF" in one position and Sony's "memory stick" symbol in the other. Apparently I accidentally reset the switch from "memory stick" to "CF" while slipping the camera body into (or out of) its carrying-case. Once I had set this switch from "CF" back to the "memory stick" position, everything worked fine. Solution:  read the user's manual more carefully next time!!
SGNath
Sujith Gopinath
  • 170 Answers
  • Posted on Feb 10, 2009
SOURCE: I downloaded card onto computer. Took the memory card out of the
Do you have the latest firmware?
Download it here:
http://www.sonydigital-link.com/DIME/digistill/Alpha/firmware/firmware.asp?l=en
Anonymous
  • 107 Answers
  • Posted on Jun 11, 2009
SOURCE: i cannot download photos from my sony cyershot
Hi Jacki:
Please unplug your camera from PC.
2- Go to ADD/REMOVE software and remove all software you installed related to your Sony Cyber-Shot.
3- Use the CD which came with your camera and install the drivers for your camera.
4- Connect your Camera to your PC.
5- Turn on the camera, The drivers for your camera would be installed automatically.
After it is finished installing, you would be able to download, delete or view your stored pictures on your PC.
If you had more questions, please email me
[email protected]
Good Luck!!!!!!!!
k24674
  • 8093 Answers
  • Posted on Sep 11, 2009
SOURCE: I purchased a Sony cybershot DSC- S930 and
The camera does not recognize the card because
1. Card not compatible
2. Camera cannot handle such a large capacity.
3.Card not inserted correctly.
Maybe a recent firmware update can address the 2nd limitation.
Hope it helps.
Importing pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I appear to have lost all my holiday photos due to a crash within the camera when the memory was reading full. Although the camera is not recognising any images on the card It still has a message saying...
you can try to get your images if you use an adapter for the memory card that connect to your computer then there is an application that recover files from a memory card
Hope it will help
Losing photos
They are probably still there. Get yourself a card reader and use it to download your pics. f1eb652.jpg
10helpful
4answers
Hello, I have a samsung es55 camera and need to retrieve some pictures after they have been deleted. I have looked online and it seems this is possible through accessing the recycle bin, thought I can't...
I'm working on the premise that you've deleted the photos from your camera memory or memory card.
If you have and used them since, its unlikely that you'll be able to retrieve them, you could have already over written them.
Its unlikely that you've deleted to your recycle bin, thats on your PC, usually already on your desktop. Camera's normally delete for good.
However, check your pc recycle bin, just double click onto it, it should be on your desk top. Once open you can choose to restore deleted files.
There are 2 file recovery programmes available for free from "filehippo.com" called "recuva" and "PC Inspector File Recovery 4.0". Download and install either of these onto your pc and recover from you camera memory to your pc (just create a folder on you desktop".
Good luck.
8helpful
6answers
I have deleted photos by error will be to recover
Dont worry, you can recover deleted photos from camera with camera recovery software.
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download asoftech photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
It seems i have lost the photos that were in tht camera. a little confused about internal memory and what that means
Some digital cameras can take pictures with out any memory card installed, some have no way to use a memory card. Most digital cameras use some kind of memory card which can be inserted in the camera's card slot. When the card is not installed, some cameras can take internally stored files, either video or picture files. In order to get those files on a card, a card must be inserted in the memory card slot then go to the menu to copy the files to the memory card.
8helpful
8answers
How do i recover deleted pictures?
you can recover photos from camera with camera recovery tool like asoftech photo recovery. First of all, do not save any new file to camera's memory card.
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtml
1helpful
2answers
Deleted photo recovery from cameras internal memory
Please try this, turn on your camera, insert a blank memory stick, slide the side switch down to the lowest point, should say “No file in this folder” click on menu, click on Setup, use the arrows and go to Memory Stick, choose “Copy” choose “Album” the “OK” this will copy all you pictures from the Album in your camera to your memory stick.
Hope this helps
J
4helpful
3answers
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
