I replaced my battaryand alternator it starts on a full battary but is not charging it - the amp meter shows the power droping as the car runs - the battary shoiws a chaerge of 12 volts when the poles are disconnected and when istalled and the engine running
To see if it would be the alt. crank the truck and disconect both bat. and if it dies than it will be the alt..
Trace the wire from the alternator to battery for a fusable link, might be burnt. Not knowing what year your truck is, I don't know if your truck has the external voltage regulator which is usually mounted on the inner fender well, or if it's built in the alternator.If it does have the external one try replacing it. Hope this helps.
I have a 2004 ford powerstroke diesel with 1 alternator put 2 new batteries in it but it seems something is draining the batteries down, checked the batteries with truck running it had 13.87 volts what else could it be, alternator or maybe a new belt or is something drawind the batteries down.
