SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
SOURCE: I have an Epic treadmill
Hi, follow the instruction below....
SOURCE: I've misplaced my manual for my Free Spirit (Sears
[from my Owner's Manual]...
On MY Free Sprit mdl 309180:
1. Remove the safety tether from the treadmill.
2. Press POWER button and hold.
3. While pressing the POWER button, insert the safety tether.
4. After lights on the LED display go out, release POWER button. You will hear a beep.
5. Press POWER button again. You are now in kilometers per hour.
* Repeat steps 1 - 5 to convert to miles per hour.
* If you are in kilometers per hour mode, you will see a "Si" in the time section when the safety tether is inserted.
* If you are in the miles per hour mode, you will see a "bri" in the time section when the safety tether is inserted.
Hope this helps,
gyro_john in Saskatoon, SK Canada
SOURCE: i have an horizon t931 treadmill and when i start
Possibly you do not have the magnet on its plate.
There is a small red magnet which is on a cord. The other end of the cord clips onto your clothes. If you fall, the magnet pulls away from the machone and it stops.Hope this helps.
SOURCE: instructions for biosync treadmill
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.
