Samsung WB850F SMART Long Zoom WiFi 16 Megapixel Digital Camera - Black Logo
Anonymous Posted on Jan 13, 2013
Cannot transfer files from samsung wb850f camera to computer
I have downloaded the disc that came with camera but the computer will not recognise the camera when I connect the USB cable from camera to computer.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Jan 13, 2013
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444259
Points
622693
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
  • Anonymous Jan 15, 2013
    Thanks for this solution. I will purchase a card reader & try your suggestion.
5 Related Answers
Anonymous
  • Posted on Jun 24, 2008
SOURCE: Camera will not download pictures to Dell computer
Have you tried starting download manually? Control Panel > Add Hardware...
Anonymous
  • 154 Answers
  • Posted on Dec 16, 2008
SOURCE: computer will not recognise my
First, make sure that there is no dirt or marks on the silver side of the CD, re-start your computer and try again. Does your cd reader read other disks correctly?
tech318
  • 19 Answers
  • Posted on Mar 09, 2009
SOURCE: No software to upload photo's... Help?
Go to Samsungs websight, software should be available for download there, if not, any run of the mill picture software will allow you to upload the images to you're computer, the main thing is to make sure the drivers are in you're computer for that particular camera, if you can't find samsungs websight try googling it, here I found the site you need this will take you directly to you're cameras support page, with all the software and drivers you will need.http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=+S730&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=+S730&isEqualsY=
be sure all of this is in you're browsers address line. and it will take you directly to the site....
Anonymous
  • Posted on Jun 06, 2009
SOURCE: have USB cord but lost the disc that came with camera
Log on to the internet and google a search for the Samsung web site. This should provide you with a link to the software for your camera
Anonymous
  • 11967 Answers
  • Posted on Oct 26, 2010
SOURCE: I've never had problems uploading pictures in the
Do not hav disc to put in computer does not recognise camera
You might want to consider getting a card reader instead. Once the memory card is inserted into the card reader, the card will appear as a disc and you can simply drag-and-drop your pictures like any other file. It will also be faster than going through a USB cable.
When I try to transfer my photos from the samsung digital camera ES70 to my computer a message come up saying "USB Device not recognised". Why?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
2answers
Samsung B3310 transferring photos to computer
You can get a cable from ebay easily enough, once connected to your PC and switched on, if you PC doesn't recognise your camera/phone, then I suggest you go to the manufacturers web site, follow links for support and/or downloads and download the respective drivers.
S860
you do,not need a driver to tranfer pictures from camera to pc,first make sure you turn camera on,highlight the words camera,click ok on your camera.the download should start,if it does,nt start you need some kind of print programs.they should help you access your pictures,also if the computer recognizes the camera as removable media. you can go to my computer,right click on it,click open and look for pictures.good luck. hope i helped
Download software for samsung L210
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa.
Downloading photos
If you are using Windows XP unplug your camera from your PC and uninstall the Kodak software. You don't need it to transfer photos to your PC. The next time you connect your camera (turn the camera on) to your computer it should recognize it and you can use Windows built in transfer software. Details are here:http://www.organizepictures.com/2006/11/5-easy-steps-to-transfer-your-pictures-using-windows-xp-photo-wizard
I was able to down load pictures from my Samsung S600 digital camera, now I am not able to do that, I donot know the problem, can you tell me what to do for down loading the pictures
There are a few different options to transfer pictures to your computer from the samsung camera.
Firstly, is your computer recognising your camera when it is switched on and plugged into the usb port? (ie, do you see various options on the screen of your pc)?
Alternatively, plug in your camera to the usb port and switch on the camera. Double left click My Computer and you should see "Samsung Digital Camera" somewhere. Open that file to see your pictures. Left click "Edit" Left click "Select all" then "copy these files" to a destination of your choice.
Does that help at all?
Computer will not recognise my nv100 camera, software disc keeps saying download incomplete when i try to remove disc
MP3 files do not play.
cannot transfer music from pc to mp3 on camera. memory card seems to have them but they will not play - says no files ???please help.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
