SOURCE: Dacor CPS 130 oven will not heat
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: the oven setting for convection bake stops at 285
I would suspect the thermostat as being bad, but it could be a heat sensor also. Here is a blog that gives general troubleshooting of this problem, and perhaps it will help:
Here's an answer I found on the web from someone that had already changed the temperature sensor:
Gas oven? You need to remove the bottom panel inside the oven and watch the burner cycle. If it's real slow coming back on, this will let temp drop too far inside the oven, which may indicate a bad ignitor.
Could be this, or a sensor, or the thermostat. Sometimes upper limit switches go bad.
I tried to bring up diagrams of your oven, but could find any one the net.
Here's some info on troubleshooting a gas range, and hope it helps:
http://home.howstuffworks.com/how-to-repair-an-oven7.htm
Good luck.
