I have a corner whirlpool tub and it will not come on. I checked the fuse box and it is ok. It has an powerbutton on the tub and a wall switch. There are no access panels to get into the tub area and I don't know where the pump would be to check it out and I don't want to tear up my walls to get in unless I have too. The tub was all ready here when I bought the house. Any ideas?
You wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
