Question about FIC K8-800T Motherboard
Memory upgrade issue
Have a FIC K8-800T mother board that came w/ 2-512mb DDR400 PC3200 non-ecc memory. Did not get a manual w/ it. Found specs of FIC site that said it could hold 2GB of memory. Purchased a 1 GB DDR400 PC 3200 non-ecc memory. Board will not boot if I have all three in the slots.
This motherboard can only have slots 1 and 2 or 1 and 3 in use. You can only use slot 1 alone, if you use double-sided PC3200 memory, according to the directions, but a BiOS upgrade might fix this.
Posted on May 01, 2009
    Genius:
  • 1,102 Answers
Can you boot to bios and see if all the memory shows
you are probably gonna need to remove your 2-512 and replace with another 1gb
Posted on Jan 23, 2009
    Sergeant:
    Champion:
  • 242 Answers
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
SOURCE:
Have acer veritron 5600g does it take high density or low density memory
Your computer can take either DDR333 MHz or DDR400MHz (pc2700, or pc3200) NON ECC memory. Even though it can take either you need to use matching modules/ not mixed. DDR400 or pc3200 memory is faster but these are also backward compatible. The memory will only run as fast as your FSB (front side bus) rated frequency. Click HERE to go to Crucial memory advisor page for your model.
Apr 25, 2011 | Computers & Internet
I have p4p800 se 2.6 ht cpu I recently bought 2-1gig sticks of ddr400 pc3200 cl3 hp memory and tried everything I could think of wont boot can anyone help
Asus gives this as the board memory spec:
-4 x 184-pin DIMM Sockets support max. 4GB DDR400/333/266 non-ECC DDR SDRAM memory
I suspect you bought DDR2 type memory.
Apr 16, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Ram used for asus P5P800S
2 x 184-pin DIMM sockets support max. 2GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory.
Or if you prefer it a bit plainer a maximum of 2 x 1GB DDR400/DDR333/DDR266 SDRAM memory.
you will find the full specs as well as the drivers on the asus global website.
Mar 18, 2010 | ASUS P5P800S (90MBL0Q0G0UAYZ) Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
RAM compatibility
you can use kingston memory, have a good price. Important rember that Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Sergio
Mar 20, 2008 | Intel D845GVSR Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Memory swap
This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
Jun 08, 2007 | ASUS P4S800D-X Motherboard
FIC K8-800T Motherboard Logo
144 people viewed this question
Top FIC Computers & Internet Experts
Joe Negus
Joe Negus
Marvin
Marvin
madadam1965
madadam1965
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
