Need a manual to know how to use the various menus on the remote
We know how to go from channel to channel....we don't know how to add favorites, dvr?, we are not utilizing 90 % of what this remote can do...is there a manual that we can order?
Once installed, you will simply
run the program and select
the devices you would like to control from
menus. This program finds the
right codes for you and loads them into
your remote control.
The last time I saved favorite channels, I had to go to my "On Demand" screen. Then, put it on the channel you want to add as a favorite. The icon I had was a "heart" and you scroll to the heart icon and click. It should add that channel to your favorites. An easy way might be when you're watching that channel, to hit "favorite" on your remote as the gentleman above suggested. I believe it depends on your Cable Provider and the type of remote you have. You can always call their technical support # and ask. They'd be happy to walk you through it.
Have you checked your parental control settings? That would be about the only way I know of the to mute certain channels. But if your locked out a channels there would normally be no video either.
Sorry I can't tell by the video but on the side is ther a menus button? And if ther is push it and go to the channel selection or add/remove channel or where u see a place to do a auto detect.. Once there u should see a add selection and u can add channels manually with the + - buttons as up and down u should be able to add the av to the section list or it will just let u select that Chanel and exit the menu automatically.. Or u can get a universal remote pretty cheep prob like 5 buck at Walmart and do it that way or if u have cable or dish that remote will program as well.. Good luck
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
Press "MENU" on the TV until "SET UP" appears on the screen.
Now press ^ or v until "FAVORITE CH" appears in purple.
Now press < or > to display the favorite channel FAVORITE CH menu.
You will use < or > to got between "SET and "CLEAR."
So now go to "SET" and press ^ or v until you get to channel 1.
If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
• Air
• Cable
• Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Probably go to the favorites menu and manually add it there? if not, when you click the address when it ends up in the recently found, is there no menus that say, maybe , add to favorites?
