Mitsubishi WD-52525 52" Rear Projection HDTV Logo
A
Anonymous Posted on Jan 12, 2013
How to clean air flow vent on 73 inch mitsubishi tv
Chris Wharton
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 22, 2018
Chris Wharton
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1171
Points
I have a blinking yellow light and tv won't turn on
5 Related Answers
hammer05
  • Posted on Jun 03, 2008
SOURCE: mitsubishi 52inch
With the 52" DLP , there are 3 fans, 2 of which you can see. the 3rd is similar to what you would see on a CPU. To get to this fan you must pull out the back of the set, at the bottom you will see a metallic channel that runs over to the filter on the side of the tv. un do the screws holding it down and you will find the mini fan. this may be the fan that is beginning to fail, as well as you will find that the heat sink is probably covered with ****, you will want to vaccum that stuff off to get the max heat exchange. To replace that mini fan, you can either go to allied or digikey to get a comparable fan with possible more CFM than the stock or go through some where you can a OEM replacement fan.
Anonymous
  • 139 Answers
  • Posted on Mar 06, 2009
SOURCE: tv cuts off after few seconds
The lamp is failing.
Anonymous
  • 1066 Answers
  • Posted on Mar 23, 2009
SOURCE: Mitsubishi TV air flow
fan could be binding and turn slower.
Steve LaHuis
  • 418 Answers
  • Posted on Apr 16, 2010
SOURCE: i have a wdy57 the tv turns on tells you air flow
search 'thermal fuse'.
Anonymous
  • Posted on Feb 12, 2011
SOURCE: i have a grey box appearing in middle of my 73
turn off closed captions (worked for me)
1helpful
How to test fans on dlp tv I have pulled the video engine
Hello. Most fan problems are dust related, and only need cleaning. A can of air should do the trick.
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
How to clean a 73 inch tv screen
If a 73 inch what type is it? A model number would tell me what to tell you to do.
1helpful
2answers
Mitsubishi 56 inch dlp,screen says tv will turn off in a few seonds,air flow seems to be blocked,tv turns off and orange light comes on???? Have to push reset button to clear orange light,this is constant...
Hello!! It might be either that the tv is overheating because of the lack of air, or it may also be your ballast.
First of all I recommend you clean the fans, so the air flow won't be blocked, don't use something that mioght damage some of the boards that are inside, you can buy one of those air cans to clean computers, if that does not work, I recommend you listen closely and notice if there's a clicking sound, if so it might be the ballast.
1helpful
2answers
Message on screen says tv will shut down ck air vents for blocks
you must have a wd series mitsubishi..the lamp tempurature sensor has a manufacturing problem..mitsubishi has an updated one to take care of the problem..the sensor itself is not bad it is the way the wires are crimped in the plug,,the new one is soldered..the part number is 299P313010A,
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
