Sony SLV-N750 VHS/S-VHS playback VCR Logo
Posted on Jan 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote ineffective. Even with fresh,tested batteries, the remote will not control any of the vcr functions, although the vcr can be operated (except for programming, of couse) directly with the controls on the vcr. Both an RCA and a Panasonic universal remote were tried without soccess. In other words, it appears that either the vcr is not sending the signals or the vcr sensor is not properly picking them up.
  • Anonymous Jan 24, 2009
    OK, I have this same problem, but you can make it work by opening the battery compartment and moving one of the 2 batteries out and re-inserting it. It's time consuming and irritating, but this is how I get mine to work. I'm currently looking for a replacement, but I fear there may not be any. Nice product Sony! It's been this way since I bought the product.
Anonymous
Level 2:
  • Expert 258 Answers
  • Posted on Jan 22, 2009
Anonymous
Expert
Level 2:
Answers
258
Questions
0
Helped
138754
Points
619
If you have a video camera with a night vision setting, wait until dark, turn out the lights and turn the camera onto night vision and look the the remote. When you press the buttons on the remote does the small led transmitter on the front ligh up. If so the remote is working but possibly sending the incorrect signals.
Polaroid vcr/dvd model 2010 stopped working
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
My audio remote control stopped working on only the volume. It works to power the receiver up or off, etc., and the volume control works perfect when operated by hand, but no longer with remote.
https://youtu.be/wUpnETSm6_k
Everything on my remote works except for my volume and channel button.
Try to set it with an other set-up code said for your device.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list,
use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code
in the code list that performs more functions. Try other codes from the code list for more functionality.
How to operate with remote control
VCR Remote Control Buying Guide ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
REMOTE CONTROL MANUAL Synergy V - RCN
help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC.../index.htm
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
www.cox.com/business/support/.../article.cox?...
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
lykohavi
My Sony remote is RM-YD024 - I am trying to find the code for a Denon DVD player, Norm.
Here are all the codes for your Denon DVD player.
30490, 30634, 31634
Just in case you don't have the manual I also included the steps to input the codes.
Hope this helps
Follow these steps to program the remote control.
NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any type of equipment that is compatible with this remote control. For example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the INPUT button.
  3. While holding INPUT button, press the FUNCTION button for the desired component.
  4. Release both buttons.
  5. NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  8. Press the ENT button.
  9. NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
  10. Point the remote control at the component.
  11. Press the component POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, use the remote control that was provided with the equipment or purchase a universal remote control that has a learning function.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
Hitachi DV-PF73U DVD/VCR Combo.Does not respond to remote control
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
Television is not responding properly to the remote
You need a brand new one of THESE and they are priced from 10.95 to 39.95 or less than the bench time to "fix" the vcr button on your remote, and since remotes are always coming up missing, you will
have a spare for all functions except the vcr and a basis of comparison for future troubleshooting processes as other functions fail, if any such failure should occur.
2helpful
I have this RCA remote and I misplaced the guidebook.
You must first find out why the remote control is not working properly. These remote controls have been having problems with new batteries. The battery holder on the positive side need to be adjusted out to make sure its making contact with the batteries. This may be the reason the remote control is not working. After you find the problem with the functioning of the remote control you can go to the RCA customer support website http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 find the codes for the components you want to use with the remote control. Use the codes to make the remote operational . This should be all you have to, if the remote control is working properly. If you cannot get the remote control to work properly, you can call the RCA customer support at this telephone number 1-800-645-4994. Give them the model number of the remote control and ask them for assistance with the problem. I hope this information help you with the problem you are having with your remote control. Thank you for using FixYa and have a nice day!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
