Microsoft Xbox 360 Elite Console - Black Logo
Posted on Jan 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xbox 360 is not reading discs an it was just work this morning
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Jan 13, 2013
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
Helped
39273
Points
422
Possibly the laser has failed, Take to a qualified technician for further assessment.
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jan 01, 2009
SOURCE: xbox 360 not reading disc
Hi
Please refer the following link to fix your issue
http://support.microsoft.com/kb/910798
Please vote if the solution is helpful
redrocknv1
  • 24 Answers
  • Posted on Mar 22, 2009
SOURCE: xbox 360
The likely hood is your spinner motor is bad. Crack the case. Take the dvd drive out and remove the top then reinstall in it original place. Don't install the plastic case. Turn it on by ejecting the the dvd (small hole on the left front use a pen tip) put a disc in then you can see if the disc spins or not if no then the spinner motor is bad. If you don't see the laser move or light up you may have a bad laser or the motor that moves the laser could be bad.
Andrew
  • 54 Answers
  • Posted on Mar 29, 2009
SOURCE: My XBOX 360 elite is not reading discs.
sounds like your Disc Drive has taken a **** I have had the same issue and I had to open it up to make the drive start to spin again
Richard T
  • 441 Answers
  • Posted on Nov 17, 2009
SOURCE: xbox 360 not reading discs
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Anonymous
  • 3153 Answers
  • Posted on Dec 15, 2009
SOURCE: xbox 360 does not read discs
Hi Rulds just STALKING
Why won't my xbox read the game?
IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
The x`box was saying it can't read the disc. contact u
If you have the new kinect xbox 360 dashboard and you cannot get your xbox 360 console to read your game discs or DVDs, you are not alone. An update that was recently applied through Xbox Live makes your discs unreadable.
Remove the update by navigating to:
System Settings->Memory->STOP HERE!
You should see your Hard Drive highlighted, if not move to it and then enter this on your controller:
X,LB,RB,X,LB,RB,X
Delete System Update will appear, make sure there is no media in your disc drive and select YES. You system will restart and appear to hang DO NOT TURN IT OFF OR MESS WITH IT!
After a couple minutes your system will start and you should be able to play discs again.
3helpful
2answers
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email [email protected] for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
My xbox 360 is not reading any disc. I tried cleaning the dics, I tried new disc and still not reading disc.
If your Xbox 360 is not reading your discs you need to stop the heat build up on the receptors at the back of the dvd drive.
To do this you need an Xbox 360 Repair guide or to send it back
Xbox 360 will not read discs
Try using different sorts of discs in the xbox, original xbox games, xbox 360 games, dvds, etc, and if nothing reads in the unit, you need to replace the laser assembly. But seeing how the unit is less than a year old, take it back to retailer or send to microsoft. Good Luck.
XBOX 360 will not read any game
It will need the laser or dvd drive replaced.
Xbox 360 Wont Read Games or DVD's
take out your hard drive and then turn it on restore factory settings and plug it your hard drive back in
2answers
Xbox 360 not reading disc
Hi
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
