ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
see this causes: It doesn't pump or spin frozen pulley pump or belt broken pump, replace+tes the lid swithc for defective and replace. It pumps, but doesn't spin lid switch defective replace+coupler broker+belt defective+clutch worn+drive motor defective+transmission drive NOT shifting properly+basket drive worn :replace It spins only with the lid closed
safety reason, will not start. see the diagram. God bless you
see this possibles cause: It doesn't pump or spin frozen pump pulley+drive pump belt broken replace It pumps, but doesn't spin lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn It spins only with the lid closed safety the machine will run with the lid door closed.
see this causes: t doesn't pump or spin frozen puller, or broken belt, lid switch defective or open replace It pumps, but doesn't spin lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn, It spins only with the lid closed for security reason, only spin with the lid closed
see the causes: t doesn't pump or spin frozen pulley or broken belt replace+lid switch open or defective replace It pumps, but doesn't spin lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn. It spins only with the lid closed for safety, only sping with the lid closed.
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
Perhaps there is a switch that detects the lid is closed that is not getting closed when the lid closes...perhaps broken. If that is the case, you can just tape it closed or get a new part that makescloses it properly. Could be a bad motor winding for the high speed turn.
