Luminox 3102 (Size: ) Watch for Men Logo
Maria Timpano Posted on Jan 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type of battery goes into Casio G shock MTG900, Module 2638
The site shows a CTL 1616, but when I call about it they said it isn't a rechargeable battery. I thought the one in the watch now is a rechargeable battery. Would appreciate any help you can give me with finding a replacement battery.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4855
Points
29
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Anonymous
Level 1:
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4855
Points
13
CTL is stand for Cobalt Titanium Lithium Rechargeable Battery.
CR is Lithium Manganese Dioxide Battery.
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Jan 22, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813013
Points
13579
The site shows the right one. To be 100% sure, you can take out original battery and read the writings- these will be exactly what you're looking for.
As these are 3 Volt Lithium batteries, they last quite a long time and I suggest that's why you thought they are rechargeable. Some of them can power up the watch up to 9 years (depending on watch movement).
When buying the new battery, do not mind the letters and manufacturers name- they may vary. Just make sure the brands name is familiar to you (SONY, CITIZEN, MAXELL, RENATA, CASIO, YAMAHA, etc) and the numbers are EXACTLY the same as on old battery, in this case 1616. Those numbers actually are the size of this particular battery: diameter 1.6 cm X height (thickness) 1.6 mm.
So, if you will get the wrong numbers, your battery will not fit in to the watch simply by size.
I hope this solves your question.
Do not forget to rate, please.
  • Anonymous Feb 23, 2011
    THIS battery does NOT have a voltage of 3 V but 2.something! In this case, there are also the LETTERS CTL important - they indicate a special sort of Lithium battery.
  • Fast300 Mar 08, 2011
    You are incorrect, CTL 1616 is a rechargeable cell and is NOT a 3 Volt Lithium battery.
    In fact a "single" cell can not be a battery at all, in that a battery, is more than one functioning together, as coined by Benjamin Franklin in his Leyden jar experiments.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8549
Points
Casio G Shock MTG-910DA 2638 Spring
You would have to make one. Why not look for the one you lost? Presumably you didn't do it outside sitting on the grass? Or return it to Casio for Service.
https://www.google.com/search?q=Casio+G+Shock+MTG-910DA+2638+battery+spring
I need the instructions for a G-Shock (MTG900) Casio watch. Please advise where I can find this. Thank you
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 13, 2011 • Watches
2answers
Mtg 900 comes up charge and says recover. What do i need to do? I tried charging it under a lamp for several hours but that does not last long.
I have a watch which is solar type and the instructions say that several hours of sunlight will charge the battery but lamps need much longer (1 -2 days!), my watch now is left in a drawer.
If you haven't got instructions for your watch, to check what Casio recommend, you can get them on the net.
watches;
Accept terms
1helpful
My casio 2638 will not stay on, always in sleep mode, how long do i have to charge it?\
Chances are the rechargeable battery will need to be replaced, the average life span is 1 to 3 years.
8helpful
4answers
Battery its ctl1616 they said NO NEED FOR BATTERY CHANGE but it's not true. How many year this battery last?
The CTL 1616 is a special device.
It's not really a battery, but a "capacitor", which means, that it's mainly supplied by the energy of the light. The capacitor is designed to maintain the functions only for (short) periods of darkness.
It's NOT a "standard lithium battery", because It has a different voltage (2.3 V instead of 3 V) and consists of different materials.
Unfortunately, the capacitor loses its ability to store the energy over the time. So your watch may be able to maintain all the functions for more than 11 months of darkness in the BEGINNING, but after a few years it may only last for a few hours!
However this may be STRONGLY influenced by the use of the functions: for example the automatic reception of radio signals or using a digital compass may strain the energy seriously.
So, the use of different functions may affect the lifetime of a CTL 1616.
I also recommend to expose the watch to (bright) light as often as possible in order to maintain a HIGH level of stored energy.
I also heared that there were serious problems with the quality of this type of capacitor a few years ago. Maybe a new CTL 1616 will last for decades.
2helpful
I need manual for Casio G-Shock MTG-900 please can you send me the manual in my mail.
you can get
watches;
Accept terms
I have a gw300 and the battery is dead and i am looking for a new battery.
Ebay: http://shop.ebay.com/idiotdoc/m.html?_nkw=Casio+G-Shock+CTL1616+CTL+1616+Panasonic+Watch+Battery]&_sacat=0&_odkw=&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
1helpful
My Casio MTG900 seems to be dead. How much is a battery and where can it be serviced near Los Angeles?
Thanks all! My G-Shock was only in need of charging in direct sunlight as opposed to indoor lighting.
3answers
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Top Luminox Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Luminox Watch Expert? Answer questions, earn points and help others
