Question about Maytag HAV3460AWW Top Load Washer
Trying to replace the motor on my maytag toploader washing machin
Model # MAV6057AWQ how do get to the motor ?? please send instructions
  • 132 Answers
Hi There,
On the bottom of the front panel there should a philip head screw right above each fron adjusting leg.
Remove these 2 screws. Open the cover and lift up on the front between the drum & cover there are 2 metal clips holding the top down. Swing the top up and remove the front panel. The motor is right in front on the lower left. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
SOURCE:
Hi i have a topload maytag washing havyload maching at home,when i start the water is notcaming in machin,other sycle rinse and sping is working....something is wrong with startign problem,,,,please g
This might sound like an irresponsible or stupid answer. But do try this...shake the machine when off and empty to 'wake up' the sensor. Then turn it on and try.
Mar 29, 2014 | Maytag Washing Machines
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag topload 1412 series 4. I recently tried to wash a comforter far too big for it. About ten minutes into the first cycle I checked on it and smelled something burning. I did not see any...
lo mas combeniente en estos casos es revisar el bobinado del motor obiamente esta quemado pero puede ser renplasado por un motor nuebo instalado por un experto en la materia
Oct 05, 2010 | Maytag PAV2300 Top Load Washer
Water will not shut off when filling on wash cycle. Pressing OFF does not stop the filling. Only solution is shutting water OFF at wall source. Is this machine worth fixing? Are parts available?
The problem is the water inlet valve has failed. This is inexpensive and easy to replace. Here is your part # AP4026989 If you need help installing try this link http://appliancehelponline.com/topload.html
all parts come with installation instructions. You can also enter your model # for diagrams and illustrations
Jun 15, 2010 | Maytag LSE7806A Top Load Stacked...
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Maytag Neptune toploader interlock system "tabs" broken
HI, You should replace it. It is for safety reasons. Please get me your model # and I can get you part# info and how to replace it.
Thanks
Vic
May 17, 2009 | Maytag Neptune Washer
Motor Hums on Top Load Maytag Washer
Hi, this is gil1714 in Scotland. Motor not starting properly, and humming. this machine has an induction
motor which has a starter capacitor on the side(the cylinder shaped object). these age out, so try replacing
with one of the same rating (printed on it ??mu). if that doesn't solve the problem, check to see if anything
is partially jamming the drum, or if the machine is overloaded . the other possibility is that the coils in the
motor are starting to fail, which would entail replacing the complete motor. hope this is useful gil.
Dec 17, 2008 | Washing Machines
Performa by maytag 8kg toploader
Click on 'washing machines' (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. Go to Maytag, look for toploaders, 8kg. Best of luck, if it's available, you're saved...........
Feb 10, 2008 | Washing Machines
betterwitch, try this link, 3 manuals for the PAV, it will be on the backside of the consol. Catriver
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=pav2200&siteCd=MT_EN_US
Jan 18, 2008 | Maytag Performa PAV2200
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag HAV3460AWW Top Load Washer Logo
253 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
