This old phone doesn't recognize a charger if it is on. if the phone dies completely, then it will display the red bar in an empty battery with a lightning bolt below when i plug in power. the phone charges to about 3%, when the phone reboots, then it stops charging and dies shotly thereafter!
Hit sounds like a cable problem to me. you can try to buy another one. Look for it for amazon. This happened to me a year ago, and I thought it is just normal only to find out it was my apple charger that went out of control. I bought another one from amazon and it works perfectly fine without any faults or whatsoever . Good luck
Lightning Cable Cell Phone Data Cable Sync and charge USB Cables for Apple...
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
i read john doe's link, but the phone works fine for the five minutes that it has charge - no trouble with repeated reloads or recovery mode.
