Microsoft Windows XP Professional for PC Logo
Anonymous Posted on Aug 15, 2017
Problem with the installation of Windows xp professional
I was installing windows xp on my old PC of 460mb ram and 1ghz processor. I inserted the CD and it started installation. I was installing and when it was at 45%, my monitor,mouse and keyboard stopped receiving signal and the CPU usage was very high. Then I lefi it for 2hrs...3hrs... but it was not responding. I turned off and restarted but it was again at the same position. Please help me.
Dai Boyce
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Oct 02, 2017
Dai Boyce
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
158117
Points
858
Go onto another computer website and get a newer version or buy a cheap upgrade version off eBay .
James Grady
Level 1:
New Friend:
  • Contributor 29 Answers
James Grady
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
3446
Points
90
Windows XP is no longer supported by Microsoft. You have to install a newer version.
5 Related Answers
Anonymous
  • Posted on Jan 02, 2008
SOURCE: Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
When Setup starts again, press F5 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen. u will be prompted to select 4 or 5 options...select STANDARD OPTION..and u r thru with ur installation...rgds
Anonymous
  • 31 Answers
  • Posted on Oct 10, 2008
SOURCE: Unable to start in Safe Mode with Command Prompt in XP Media Center 2005
Hi there. My name is Alex and I am here to help solve this problem
Depending if the BIOS has legacy USB support for keyboard and mouse enabled, you should be able to run safe mode by pressing F8 before the computer boots into windows. I would not recommend going into the BIOS if you do not have much knowledge to the computer as one wrong configuration could cause some behaviour problems or even damage to the pc's components
I recommend connecting a keyboard and mouse that have cable and the PS/2 connectors (purple and green) which can be found at back of the computer at the top. Then restart your computer, hold down F8 and you will be able to run safe mode. The mouse and keyboard will then work
Keep both the keyboard and mouse plugged in and boot windows. When you get into windows, plug in the USB keyboard and mouse into a USB slot and wait whilst it detects it. After a couple of minutes you should be able to use your USB mouse and keyboard and take out the PS/2 keyboard and mouse
I hope this has helped. Please let me know if you have any questions or need further assistance.
Anonymous
  • 51 Answers
  • Posted on Apr 01, 2009
SOURCE: i have windows vista home premium on sony vaio
Here is a step by step guide of how to dual boot.
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Anonymous
  • 61 Answers
  • Posted on Sep 29, 2009
SOURCE: Win XP - The keyboard and mouse hang
Try booting to XP with a last Known good configuration.
After you switch on the computer, keep tapping the <F8> Key on the keyboard., you will see a list of options, select "Last known good configuration" and hit the Enter key...., Hope this works
BLAZZ81
Matthew Albert
  • 281 Answers
  • Posted on Dec 01, 2009
SOURCE: Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
1helpful
I need a bigger processor for my ibm windows xp professional
You cannot install a faster CPU but you can speed up the computer by installing more RAM.
If it was me I would put my money towards a new computer, if will be heaps faster the your old XP computer.
1helpful
3answers
I want to install win7premium32-bit to my pc
It requires at least 2 gb ram and c2 duo or higher. Be sure you have that min with your pc. next you need windows cd. insert it int drive and press F3 or any key to boot with cd. It's then very simple just do as pc says. In format using type choose NTFS next just proceed as directed and you are done.
2answers
Can I install Windows XP Professional on an Emonster 600 ?
Yes you can...
Installing Windows XP on a Emonster 600 is the same process as installing Windows XP on any Windows-compatible personal computer. The process is not difficult, and can be completed quickly.
#1 Insert the Windows disc and restart your computer. When prompted to press any key to boot from the CD, press a key. Windows will begin the set-up process.
#2 When a list of hard drive partitions appears, delete each of them by pressing "D" to delete and "L" to confirm deletion. When finished, you should only have one choice: "unpartitioned space."
#3 Press "Enter", then format using the NTFS file system. Do nothing while Windows begins to install.
#4 Wait for Windows to restart. When the process continues, enter the product key, the time and time zone, and your name when prompted to do so. Allow the installation to continue; it may take some time.
#5 when Windows restarts again, continue the process using the on-screen instructions. The process will vary depending on your hardware configuration.
#6 Connect to the Internet and activate Windows once you reach your desktop. If you can't, you can also activate Windows over the phone. Installation is complete.
I install flash cs3 in my pc but canot open it
Installation of Adobe Flash CS3
Minimum system requirements
Windows
•Intel® Pentium® 4, Intel Centrino®, Intel Xeon®, or Intel Core™ Duo (or compatible) processor
•Microsoft® Windows® XP with Service Pack 2 or Windows Vista™ Home Premium, Business, Ultimate, or Enterprise (certified for 32-bit editions)
•512MB of RAM (1GB recommended)
•2.5GB of available hard-disk space (additional free space required during installation)
•1,024x768 monitor resolution with 16-bit video card
•DVD-ROM drive
•QuickTime 7.1.2 software required for multimedia features
•Internet or phone connection required for product activation
•Broadband Internet connection required for Adobe Stock Photos* and other services
Macintosh
•1GHz PowerPC® G4 or G5 or multicore Intel® processor
•Mac OS X v.10.4.8
•DVD-ROM drive
Do you system meet the minimiun hardware requirement?
1helpful
2answers
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
2answers
What are all softwares required to install .net3.5 framework
No deed of various software. But you have to have .net framework 2sps and .net framework 3.
Download from here.
Its compatible with Windows Server 2003; Windows Server 2008; Windows Vista; Windows XP
You need Windows Installer 3.1(v2)
or Windows Installer 4.5
Its good to have .NetFW 2.0 SP1
or
.NetFW 3.0 Recommended
Upgrade it to SP1
.NetFW 3.5
.NetFW 3.5 SP1
All of these are 32 bit packages and if you want any 64 bit package, go to Microsoft.
Other Requirements. - HW
Processor: 400 MHz Pentium processor or equivalent (Minimum); 1GHz Pentium processor or equivalent (Recommended)
RAM:96 MB (Minimum); 256 MB (Recommended)
Hard Disk: Up to 500 MB of available space may be required
CD or DVD Drive: Not required
Display: 800 x 600, 256 colors (Minimum); 1024 x 768 high color, 32-bit (Recommended)
Please be kind enough to rate this answer.
Enjoy.
Best of Luck
2answers
Need to know how can I upgrade from windows 98 to windows xp professional
Here's What You Need to Use Windows XP Professional • PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
you may/will also need software drivers for all hardware eg: printer,sound card, video card...good to gather BEFORE you upgrade.
Soooo, if you have the required compnents and some free time and a little patience it can be done.
Just buy a xp pro cd if you haven't one already and git er done..
2answers
Old gateway essential 400c PC
yes, a 400 mhz processor can run windows xp, but you will want to have a LOT of ram. i would not recommend it unless you have at 256-512 or more ram.
windows 2000 can get along with 128-256 ram.
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
Macintosh Requirements
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
