1997 Jeep Grand Cherokee Logo
Posted on Jan 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1995 Jeep Cherokee Radio replacement
I am trying to either replace my husbands radio or install an xm system. The XM sytem he has is older version that needs to be hard wired in through the antenea and does not work through the radio.
Anonymous
Level 3:
President:
  • Master 1,990 Answers
  • Posted on Jan 22, 2009
Anonymous
Master
Level 3:
President:
Answers
1990
Questions
Helped
910016
Points
6127
Most of the New Aftermarket Stereo's now have the Connections for Sirius and XM Built in so you just need the Sat. Install Box. Really Simple. If you want to go a Cheaper Route Just Purchase the XM or Sirius Reciever and Mounting kit for the Dash or Windshield and It will play through an Empty FM Station on the Radio Via the FM Transmitter. Got one in all of my Vehicles and they work Great!
2answers
My radio on dash says to calibrate . How do I calibrate the radio on 08 Pontiac g6
It takes scanner to do it. Not all scanners can do it. Call before going. Dealers can do it.
Change radio setup to scan frequency from evry 200khz to evry 50khz
  1. Radio ON, tune to the XM channel 0 and record the radio ID. The radio ID will be required for activation of the new receiver.
  2. Call XM radio to deactivate the faulty receiver and activate the new receiver.
    • US: 1-800-556-3600
    • Canada: 1-877-438-9677
  3. Park the vehicle outside in an area with an unobstructed view of the southern sky.
  4. Leave the vehicle outside with the ignition switch in the ACC position and the radio ON, tune to the XM channel 1 for 30 minutes to activate XM service.
  5. Once activated, the radio will receive the remaining XM channels.
  6. XM is trade mark
I have a 2011 Honda Pilot. When I push the XM button it won't even change over to the XM radio. It is like there is no XM capability in my car. What can I do?
Often times you'll need an aftermarket integration kit to get an XM ready car radio to work. This is a two part system including the tuner to tie the subscription to and a translator to code it so the radio face will understand and display the information accurately. You can find such a kit for your car here: http://www.tss-radio.com/isimple-factory-ipod-xm-integration-for-honda-acura-vehicles-hd1.html
1helpful
My 2008 honda accord xm radio stopped working.
If it is a built in system, which is sounds like it is. Your XM receiver is not functioning correctly. I believe a replacement XM receiver is covered under your warranty if you have one with your Honda dealership.
1helpful
2answers
XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
6helpful
2answers
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Cadillac 2006 SRX XM Radio will not activate
Get your subscription refunded. There is nothing wrong with your radio. if they can't make it work, don't pay them.
2helpful
2answers
Radio Not Working
There are 3 fuses in the interior fuse panel that feeds radio.
no. 11(10amp) is ignition switch power to the radio it comes into radio on the TN/LB wire.
no. 27 (10amp) is hot at all times and comes in on OG/LG wire.
no. 12 (5amp) is hot in run or accessory and comes in on YE/BK wire.
Check these with 12V test light at fuse and at radio connector.
Replace satellite system in 2007 saturn aura xr
If you are looking to convert your radio from XM to Sirius, there are a number of kits available by typing 'convert radio from XM to Sirius' into your favorite search engine. But why bother? XM and Sirius have merged and you can now get Sirius programming on the XM band.
4helpful
2005 Honda CR-V won't go to XM radio.
"XM Ready" means that you have to have a satelite radio installed in order to have XM service. I went through this when buying my 2005 CR-V and thought that all I needed was to set up the service. If you have an XM receiver installed you can controll it on your Honda factory radio. It is very misleading.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
