Question about Nordic Track X11i Commercial Incline Trainer Treadmill
Nordictrack x11i belt stops unexpectiningly - Nordic Track X11i Commercial Incline Trainer Treadmill
NordicTrack Treadmill Summit 5500 starts normally and runs about 5 minutes then stops, console lights remain on. Unplug safety key and plug back in, starts and runs another 5 minutes and stops ----.
there 3 things that you observe:
1) The walking belt is too Tight, the deflection will be 2-3" when you lift with his finger.Adjust the https://www.youtube.com/watch?v=XyPedy7HtzM
2) the thermic swithc of the motor Tripp for the tension of walking belt.
3)the driving belt of belt motor too tight. Deflection will be 1/8" loose the bolts of motor, and adjust.
Blessing.
cuadra2016@yandex.com
whatsApp:+50588611441
Oct 31, 2017 | NordicTrack Exercise & Fitness
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
How should I lube my NORDICTRACK X11I
Check the video all the treadmill follows the same procedure of lubricating it.
Oct 08, 2013 | Nordic Track X11i Commercial Incline...
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Nordictrack EXP 1000 belt runs but stops when I get on it. Drive belts are tight
1) Try to loose a little the drive belt, for to avoid a higher tension.
2) LUBE very well the deck belt, must shure is worn, proceed with the instruction manual maintenance.
3) Test the input voltage motor, if there are voltage the motor need repair
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faultyl.
See my personal TIPS for HELP.
Try to RUN THE software calibration for diagnose, and troubleshooting
sincerely. God bless you
Apr 24, 2012 | Nordic Track Nordictrack Exp 1000...
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack EXP1000i stopped in the middle of program
Your drive motor is over heating. Usually caused by friction from the walk belt. The belt needs to be lubricated. (silicone only) Loosen the adjusting screws on the rear of the macine ten revolutions lift up the belt and using a spray silicone lubricant (from any big retailer) spray a light film on the deck (walk board). Retighten the adjusting bolts ten revolutions. If this does not help I would suggest replacing the walk belt. Good Luck, Tim
Nov 11, 2009 | Exercise & Fitness
Nordic Track X11i Commercial Incline Trainer Treadmill Logo
201 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
