SOURCE: refilling system
same problem.. "fill system press steam" but no water was flowing. The pump has an air bubble in it. capressa customer service advised to continue (up to an hour of retrying if necessary) pressing the steam button, let the machine rest for a few minutes and retry again and again until the water starts flowing. Sure enough, after 45 minutes, and 30 or so times of pressing the button, it started to work again. While I was wasting away my saturday morning with this, Williams Sonoma said that they would have the machine repaired at no charge and have it shipped back to me if I wasn't able to get it working. I've owned this machine for almost 5 years (bought in Jan '05) and this is the only time I have had a problem. ..and to be fair, I had let the machine sit for several weeks without use, or water in the tank, when I encountered this problem.
SOURCE: Hi, our Jura Impressa Xs90
Have you run a decal recently? This normally happens when a small particle (normally) an undesolved piece of the decal tablet is stuck in the flow meter, or sensor.
You can try and run warm water through the system and after about half a tank it should be sorted out.
